Question about HP PSC 1110 All-In-One Thermal Printer
I cant print
Hi! i had my hp 1110 for two years now and when i run out of inks i used my other printer but after 5 monhs i tried adding up ink on its cartridges with compatible one and i can't print now. should i change the cartridge or is there something wrong with my printer? another problem is i lost the cord for the printer to my PC where can i have one?
    Novelist:
  • 208 Answers
I DON'T KNOW WHAT YOU ARE SAYING ABOUT " ADDING UP INK ON ITS CARTRIDGES WITH COMPATIBLE ONE". IF YOU USED THE DISCOUNT REFURB, INK CARTRIDGES, A LOT OF TIMES THESE WON'T WORK RIGHT. I WOULD CHANGE TO THE CORRECT CARTRIDGES FROM HP AND TRY TO PRINT AGAIN. IT IS NOT A GOOD IDEA TO LEAVE OLD CARTRIDGES IN A PRINTER FOR A LONG TIME IF EMPTY, REMOVE THEM. IF THE PRINTER IS NOT GOING TO BE USED FOR SOMETIME, REMOVE THE INK CARTRIDGES. AS FOR THE CORD, MOST PRINTERS USE A COMMON CORD FOUND AT MOST DISCOUNT STORES LIKE WAL-MART,K-MART ETC. YOU SHOULD FIND ONE THERE.
ARCLIGHT1217
Posted on Nov 05, 2008
Printer will not print. a new ink cartridge was
There could be several solutions to your problem. You could start with the easier solutions.
You can try to turning your printer off then on.
If the printer cartridge is a new HP cartridge, try taking it out and put it back on and see if this works. try it a few times. Make sure that you take the protective cartridge printer film off.
If not, try rebooting your computer.
If not, try deleting the printer's software, rebooting your computer and reinstall the printer's software if you have the CD install disk.
You can always try to disconnect your printer from your computer, connect it again and see if it works.
You can try to use a combination of the solutions mentioned above.
If none of this solutions work, contact me.
Sep 04, 2013 | HP LaserJet Office Equipment & Supplies
HP officejet 6500 does not dispense ink
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 12, 2012 | HP Office Equipment & Supplies
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
Dell 1110 Printer .....when prints there is a mark every 3/8 " or
You may have a problem with the ink cartridge/toner. Try using a different one and print a sample page.
Nov 25, 2008 | Dell 1110 Laser Printer
Refilling HP 56 Cartridge
USING THIS TYPE OF REFILLS JUST ISN'T A GOOD IDEA. THE INK IS NOT THE SAME AS HP CARTRIDGE INK AND YOUR PRINTER WAS MADE FOR HP INK, NOT SOME GENERIC BRAND. THE FACT THAT IT DOESN'T WORK UNLESS YOU STICK IT IN WATER, ETC. SHOULD TELL YOU SOMETHING IS WRONG HERE. REFILLING IS MESSY, AND CAN CAUSE LEAKS IN YOUR PRINTER AND REALLY MESS THINGS UP. THE BEST BET IS TO USE THE PROPER INK CARTRIDGE WITH YOUR PRINTER. THATS THE TYPE OF INK IT WAS DESIGNED FOR.
ARCLIGHT1217
Jun 05, 2008 | HP PSC 1110 All-In-One Thermal Printer
HP Deskjet D4160
hi,
Ink-backup mode lets you continue printing with one print
cartridge when the other print cartridge has run out of ink.
Ink-backup mode allows the printer to operate using only one print cartridge. It is initiated
when a print cartridge is removed from the cradle.
Exiting Ink Backup mode
Install two print cartridges in the printer to exit ink-backup mode.
Cheers !!!!
Feb 15, 2008 | HP 83 3-ink Black UV Cartridge Multipack...
HP psc 750
hi, try reinstalling or upgrading your driver, if you dont have one try www.driversguide.com let me know
Nov 30, 2007 | HP PSC 750 All-In-One InkJet Printer
Massage unsupport ink on lexmark X4270
Sadly, not all inks are created equal, and even inks that are claimed "compatable" are not allways safe. My HP photo printer worked great for 2 years, then I put in a "will fit" from a name brand office supply store, the printer nozzles plugged on the second print, never to print correctly again. My replacement printer is a Kodak 5300 all in one, chosen for low ink costs/ hi-output, and I get photo-lab quality, borderless prints day after day. (I'm a photographer/artist) I have run 6 color and 5 blacks for thousands of graphics, in a period of 2 months getting ready for a showing, with maybe 1 or 2 misprints.
Nov 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Printing problems
Are you using remanufactured cartridges? If so, I would strongly recommend that you replace with factory HP cartridges.
Apr 17, 2007 | HP DeskJet 920c InkJet Printer
HP PSC 1110 All-In-One Thermal Printer Logo
Seeker5211
Seeker5211
