Bad caps Big Irish, can you please explain why you would replace the 1000uf caps on the WD52525 DM pcb with 680uf? I saw the below advice you provided and was wondering if this was a factory fix. (check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
  • 927 Answers
Good Day, newgman;
Yes, this is what MIT. says , you might call it a modification.
Good Luck, big IRISH.
Posted on Aug 26, 2008
This is a power board going to the lamp of the DLP MITSUBISHI TV I HAVE THE NEW LAMP BUT THERE NO POWER GOING TO THE LAMP THE TV HAS POWER IT WON'T LIT THE SCREEN
there are bad capacitors on the power supply.
look for bulged caps
they look like this
replace the big ones on the power supply to fix the lamp issue
there are more bad ones inside typically on the dm and fmt boards
they are 1000uf - replace those ones with 680uf @ 16v caps
let me know if i can be of further assistance
Jun 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi DLP WD62725 TV after powering down the timer light say blinking till unplug it then reset it to turn back on can any one help me
Good Day,
More than likey you have bad caps on DM Board.
It willcost about $450 to repair or you can do it yourself,.
On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V,
The DM PCB is on the left hand side of the TV when you take off the back cover.
Good Luck, BIG IRISH,.
Dec 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing power light tv wont come on mitsubishi 1080
If the tv has the continuous flashing led, you have a DM board problem. It is likely bad capacitors in the DM module.. there are 4 of them 1000uf caps that will go bad. They will get a bulging top on them when they go bad. . Mits recommends replacing them with 680uf caps with a comprable or higher voltage rating. The DM module in on the left side of the set (viewed from the back) and is somewhat difficult to remove.
Dec 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Timer light blinking green/tv won't turn on
The DM moduel is bad. You can fix it by replacing 4 filter caps on the DM moduel. Do not replace them with the same type that is in there. You need to replace them with 680u 16v electrolitic caps. They are easy to find. Pull out the DM board, they are at the corner of the board and the tops of the caps are bubbled out a little.
Nov 14, 2008 | Mitsubishi WD-62327 62" Rear Projection...
WD-52725 Jumping picture
Good Day;
Sounds like you may have a bad Format Board.
Sep 12, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd-52525 dm board capacitor replacement
Good day, husker_shoe;
Good question, but I'm not THE FAMOUS "TECHMAN" but I will try to help anyway. The DM board is normanlly on the left side TV looking from the back. It has a shield around it, remove. The caps are big and black, they look the replacements(only ones on board). Here's what says about this issue:
If the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). (LED does not stop blinking after plug in) On the DM
Good Luck, big IRISH. ps hope this helpful!
PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
It is not an easy job, it will take some time but since you have it apart there is another problem that will accure so might as well do this too:
Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
All the parts have location numbers like C8F29 that will tell you what and where these parts are.
Good luck, big IRISH. PS; I hope this helpful.
Jul 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd52525 capacitor replacement
Good day, krause67;
Jul 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power supply
Good question, I will try to help anyway. The boards are on the left side TV looking from the back. It has a shield around it, remove. The caps are big and black, they look the replacements(only ones on board). Here's what says about this issue:
PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 uFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Good luk, big IRISH.
Jul 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi power board pcb post
Good day, steve sc;
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
