Question about Car Audio & Video
Installation of Blaupunkt radio RCM 148
I am installing this radio in a non-motorcar situation. The installation instructions are pretty clear. Connect red (and yellow) leads to the battery positive and the black to battery negative.
However, I am using a harness supplied to me by Clarion and I have checked and double checked and they appear to be completely compatible.
Nevertheless, the radio will not switch on. this may, of course, be because the readio is faulty but my thoughts turn firstly to whether I am making the correct assumptions regarding the connection of the battery.
Maybe you can help me here?
  • rotarytank Aug 27, 2008
    Many thanks for this info. I am following it up with the e-bay seller you recommend. I'll try and remember to let you know the outcome.
I have one of these and it stumped me for days. There are security code entry buttons on the TOP OF THE UNIT, where you need to enter a code before any power gets through. It's really weird! I didn't have the code, but Blaupunkt gave me it for free when I told them the serial number, so definitely worth a shot. It is really odd but that's your problem, you need to enter the code manually before you get any power
Posted on Jun 30, 2014
  • 30 Answers
I believe this radio locks itself when the power is removed for a certian amount of time. If you know what vehicle it was from and the serial numbers are intact contact Ebay item#150285665841
and he may be able to help you. Good Luck.
Leadispenser
P.S. Auction is in Great Britain
This is theToronto model .
Posted on Aug 27, 2008
2008 ford f-350 passenger air bag flashes 1-7 code than stays on when truck is started.What does the code mean and can the code be reset without tearing air bag out of truck?
If a SRS fault exists, the RCM sends a message to instrument cluster module to flash a coded sequence which is called a lamp flash code (LFC) on the air bag warning indicator. Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle. In addition to the self-test at start up, the RCM continuously monitors all of its external and internal circuitry for faults.
While the LFCs are an indication of a general concern in the supplemental restraint system (SRS), the DTCs are more specific. The DTCs can be retrieved from the RCM with a scan tool via the DLC.
DTC a c LFC b Description Action To Take - Continuous Lamp The Air Bag Warning Indicator is Illuminated Continuously (RCM Disconnected or Inoperative, Loss of Battery Feed or Loss of Signal Ground) Go To Pinpoint Test A . B1048 c - Passenger Side Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test B . B1049 c - Passenger Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test C . B1054 c - Driver Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test D . B1057 c - Driver Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test E . B1231 13 RCM Crash Data Memory Full INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) and Inspection and Repair After a Supplemental Restraint System (SRS) Deployment in this section. B1317 Continuous Lamp Battery Voltage High REFER to Section 414-00 . B1318 Continuous Lamp Battery Voltage Low REFER to Section 414-00 . B1342 24 RCM is Faulted INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) in this section. B1871 25 Passenger Air Bag Deactivate Module Fault Go To Pinpoint Test F . B1884 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Circuit Failure Go To Pinpoint Test G . B1890 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Short to Battery Go To Pinpoint Test H . B2292 33 Restraint System - Seat Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test I . B2292 34 Restraint System - Seat Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test I . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault Go To Pinpoint Test K . B2434 53 Driver Seat Belt Buckle Switch Circuit Short to Ground Go To Pinpoint Test L . B2435 53 Driver Seat Belt Buckle Switch Resistance out of Range Go To Pinpoint Test M . B2477 54 Module Configuration Failure This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2607 57 Harness/Configuration Mismatch This DTC indicates the RCM is configured incorrectly. CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. B2691 53 Seat Belt Buckle Switch Circuit Fault, Front Driver's Side Go To Pinpoint Test N . C1414 29 Incorrect Module Design Level VERIFY RCM part number is correct for vehicle.
CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. U0100 14 Lost Communication With ECM/PCM REFER to Section 418-00 to diagnose the communication concern. U2023 14 Fault Received From External Node REFER to Section 418-00 to diagnose the communication concern. U2050 14 No Application Present This DTC indicates programmable module installation (PMI) has failed. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. a DTC: Diagnostic trouble code, retrieved using scan tool.
c Cross-link DTCs will be retrieved in pairs to identify the cross-linked components.
b LFC: Lamp fault code, flashed on air bag warning indicator.
Apr 18, 2017 | Ford Cars & Trucks
No clear installation instructions for electric box on air vent
Go to their website, they have installation instructions, pretty simple
Jun 19, 2010 | Air Vent (53857) Fan
I need an user manual for blaupunkt rcm 148
tengo un reproductor que no enciende y que tampoco lo lee la computadora, y no se si carga porque no marca nada en la pan talla, nadamaas se calienta el reproductor.
Dec 16, 2009 | Car Audio & Video
I have a blaupunkt chicago rcm 169 radio how
According to my database the BP Chicago RCM169 uses a SMARTCARD and does not require a code.
No free solution
Available from your Main Dealer or a Decoding Service only
Nov 20, 2009 | Blaupunkt Car Audio & Video
How to tune in stations on blaupunkt siena rcm 148
Thats an amplifier, not a head unit. The point of that is to power the speakers. The output on the head unit plugs into this, and the speakers plug into this. You tune the station on the head unit in the dashboard
Oct 08, 2009 | Blaupunkt THA125PNP 300 watts RMS x 1 at 2...
Connecting lead for Blaupunkt CDC-A03 changer
If you can find the installation instructions, you may be able to use individual spade connectors either male or female and connect direct.
BLAUPUNKT CDC A03 Operating And Installation Manual Page 9
Or try somewhere like Crutchfield
Blaupunkt CDC A03
Mar 02, 2018 | Blaupunkt CDC-A03 10-Disc CD Changer
Travel pilot E2 - unable to calibrate, either auto or manual.
you must have the speedpulse conected with out it conected it will not callabrate
Mar 01, 2008 | Blaupunkt DX-V GPS Receiver
What cd changer do I need for the Blaupunkt Sydney rcm 126W head-unit
where can I get a replacement display for my blaupunkt sydney rcm 126
Nov 26, 2007 | Blaupunkt CDC-A08 10-Disc CD Changer
Car Audio & Video Logo
281 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
