I unpluged my viewsonic VG2030wm the other day. The day after I turned on my computer///forgetting to plug in the I did that while the computer was turned on. As soon as I did this the resolution was terrible. I have the latest drivers intalled for both the monitor and the graphics card. I am able to get the srceen resolution back to normal by unplugging the dvi cable and plugging it back in......but the monitor goes back to bad resolution eveytime I reboot...or the computer goes into hibernation....!!! Please help
  • 110 Answers
While connected, try going to the device manager and uninstall your graphics card from there "(it should be listed under "Display Adapters.")
Restart at that point, and the graphics card should automatically re-install itself from the OS
Posted on Aug 24, 2008
I lost my high resolution on the screen when I use it on Ubuntu 12.04.
May 01, 2014 | ViewSonic VG2030wm LCD Monitor
No signal from computer total while screen only
Wideo cable not seated check both ends reseat check for a broken pin etc
Try it on a different computer
Aug 26, 2010 | ViewSonic VG2030wm LCD Monitor
My monitor keeps say out of range, at first I thought it was a problem with driver but I did everything Viewsonic said to do, I think it is my monitor, is there anything I can do?
that is either resolution problem or animation picture problem your motherboard is with in built dispay card which do not support to high resolution .for that you have to install AGP card into AGP slot then you can see better video .if you want to see low resolution normal computer then restart the computer and press F8 and keep pressed untill options will come then select last good known configuration then enter problem will be solved
Mar 09, 2010 | ViewSonic VG2030wm LCD Monitor
ViewSonic VG2030wm speakers not working
you are unable to get an image on your ViewSonic monitor, first check that the necessary cables are attached correctly and that the proper drivers are installed. ViewSonic offers drivers for download directly through its website (see Resources).
Some LCD monitors use a VGA input while others take advantage of the newer DVI interface to provide a connection to PCs (some ViewSonic monitors offer both types). When connecting your monitor for the first time, you'll need the right type of cable for both your monitor and computer. In some cases an adapter may be necessary to convert the DVI signal from your monitor to work in a VGA input on your PC.
Check that the VGA or DVI cable is tightly attached to the back of your monitor and to the back of your PC. Use the small thumb screws on the ends of the connectors to keep everything tightened in place, which will prevent the cable from getting loose.
ViewSonic monitors also use a power cable to plug into a power source. If the power light does not comes on, check that the power cable is inserted fully into the back of the monitor and that it is plugged into a working wall outlet or a reliable surge protector.
Mar 06, 2010 | ViewSonic VG2030wm LCD Monitor
My ViewSonic VX910 monitor will not turn on, It just blinks on and off every 5-6 sec
Try unplugging it wait a while and plug it again. Sometimes that cures the problem, but I can't promise you it will. i had an HDTV that did that. I unplugged it for a while, and it never did it again.
Nov 25, 2009 | ViewSonic VX910 19" LCD Monitor
LCD shows only Gray when turned on.
You should try VGA and/or Digital Video output.
Aug 08, 2009 | ViewSonic VG2030wm LCD Monitor
Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
Oct 15, 2007 | ViewSonic VG2030wm LCD Monitor
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
