E50 code is for a motor issue or main PCB fault on the motor output
side (also called E51 when the triac that is on the main control board normally shorts out due to a faulty motor).
Not easy to diagnose as a diy job, but you need to find out if the
drum rotates correctly when fully loaded. Could check this CODE LIST
Hope this helps.
