Question about Ricoh Office Equipment & Supplies
  • Ricoh Master
  • 2,794 Answers
Your copier may need developer if the cycle count is over 150,000 copies. Once that is added to the toner the Toner/Developer sensor should be calibrated and should work fine.
Sometimes the drum can create light copies if it was exposed to light from being out of the machine or leaving the door open too long on the side of the machine letting light in.
Posted on Aug 24, 2008
How do i fix the error code sc 322 of my ricoh 3045 copy machine?
Have to open the Laser unit and clean the laser diodes carefully.
Dec 28, 2015 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Ricoh copy machine its making light copies what's
Clean the optic's & replace the drum & the developer..
May 22, 2012 | Ricoh Office Equipment & Supplies
How do i add developer toa ricoh ft 3713?
Vac and clean the developing unit then replace the developer
but if the case is developer spilling we need to replace the 4 bushings and seal then replace the developer
Aug 22, 2011 | Ricoh FT3713 Copier
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Error codes
Try to check the fuser section.
- Check the Lamp
- Check Motor Assembly
Sep 12, 2008 | Ricoh FT5832 Copier
Replacing toner
Check the developer.
Jun 17, 2008 | Ricoh Aficio 250 Copier
Added new toner but light won't go off. Ricoh FT 3713
The TD sensor got disconnected or is broken, the copier needs service because it's not detecting that it actually has enough toner inside to copy.
Apr 30, 2008 | Office Equipment & Supplies
Toner light will not go off
Did you remove the tape from the toner bottle when you installed it? It may just be looking to add toner back to the developer, to bring it back to the set level of toner? See if it stops
Apr 28, 2008 | Office Equipment & Supplies
113 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
