Question about Kitchen Ranges
I have a ceramic NEFF hob. One of the residual heat indicators is not going out, even though controls are off, and hob is cold.
  • 639 Answers
I'm Neil
No problem
Sounds Electronic
There may be an electronic problem !
Call service!
Thank You for asking!
Neil
Please rate my solution
Posted on Aug 24, 2008
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
May 28, 2009 | Neff 23 in. T4343 Electric Cooktop
Neff T1722SO Ceramic Hob - rings don't heat
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Mar 08, 2009 | Neff Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
Aug 21, 2008 | Neff 23 in. T1443 Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Kitchen Ranges Logo
227 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
