Question about Canon PIXMA MX310 All-In-One Printer
Only printing the first half of the page
When I want to print a Word-document, MX310 is only printing the first half (or less) of the page and then give the message that 'an error has occurred'. I already tried to reinstall the darn thing but the problem remains the same. What can I do next?
    Novelist:
  • 110 Answers
Try,
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Posted on Aug 24, 2008
Hey im trying to help my sister out with some documents, only it was originally 4 pages which ive manged to get down to 2 double sided documents (ie 2 pages back to front) and now i cant seem to be able to...
Open the saved document then click file print. Then when the print page comes up on your screen set the printer to print to as Microsoft Document Writer. Which is a virtual printer. Then click print, save the file on your computer either my Documents or on the Desktop. Click print.
It will then print your document to a file.
This file can then be attached to an e-mail.
Let me know how it goes!
Take care!
damnor01
Jun 08, 2011 | Canon PIXMA MX310 All-In-One Printer
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i print addres on envelopes on mx310
Yes through MS Word.
Go to the file menu select page setup select the paper tab and then from the drop down menu select paper size and select envelope. If you have multiple options for envelope like envelope9, envelope10, envelope11 etc. select the envelop size that you want. The paper size of the document will change to the specified envelope size and then you can print the document normally using any printer.
Jun 22, 2010 | Canon PIXMA MX310 All-In-One Printer
WHen printing from MS Word academic version, the canon MX310 will print 1 page across multiple pieces of paper, at random. The drivers have been reinstalled. Any ideas?
Many programs allow you to change the size of the page for the document you are creating. If the size of the page defined in the program is different than the size of the page set in the printer driver, the document may print too small or over multiple pages.
In the application you wish to print from, check for a 'Page Setup' option in the 'File' menu. Make sure that the defined page size in 'Page Setup' matches the printer's settings. If you are unable to locate 'Page Setup', consult the application's 'Help' files or manual.
Jan 09, 2010 | Canon PIXMA MX310 All-In-One Printer
I just received a fax on my Cannon Mx310 but I
mailcenter12 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't access fax held in memory
justyourt916 --
I found this at:
Hope this helps!
-- RT
Sep 08, 2009 | Canon PIXMA MX310 All-In-One Printer
Prints only on left side of page.
In printing web pages and email please try to check also the print setting before you print the page cause word document files and web pages are not the same in there printing setting. Web pages and emails has different setting so my recommendation is that when you print email and webpages next time then please check the printer settings then modify it the same settings as you wish or as your word document's output.
Thanks
Aug 18, 2009 | Epson STYLUS R230 InkJet Photo Printer
Print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Aug 13, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
199 people viewed this question
old marine
old marine
