Question about Kitchen Ranges
Converting naturalgas to LP
HOW DO I CONVERT MY VULCAN 3 STACK PIZZA OVEN TO PROPANE
  • 640 Answers
The regulators,gas valves and orfices need to be changed for a lp retofit.
Posted on Aug 24, 2008
How to convert gh45 vulcan strove from gas to propane
Usually converting from one to the other is a matter of changing a needle in the regulator , some of them you just remove needle and flip around , or change the regulator ,
Sep 16, 2014 | Motorcycles
Need to know how to convert from natural gas to propane. vulcan oven,.. model 60XL77R. thanks!
I am looking to change from propane to gas. Willing to swap parts
Mar 16, 2011 | Ovens
We purchased a used Vulcan Steamer model # VSX10GC which was set up for propane. We need to convert it to Natural Gas. How do we do this and how do we get the parts
Please be careful when converting appliances form natural gas to propane. Depending on the equipment there are several changes that need to be made. You will at least have to change burner orifices and convert or replace the gas valve. Some gas valves are not convertible. What many people over look are changing the pilot orifice and on some appliances like braising pans, griddles and char broilers there is a runner tube orifice. The gas valve also needs to be adjusted to the proper manifold pressure and pilot adjustments will be required. I recommend on Vulcan equipment that you contact Hobart Service since they are factory trained on all Vulcan cooking equipment.
Mike
Mar 11, 2011 | Vulcan Hart VSX5G Counter Convection...
Natural gas to propane
changing from natural to propane requires different jet sizes and repositioning of the air mixture shrouds
working with gas is not in the domain of diy as you have found out so get in a gas fitter to do the conversion properly with out risk of an explosion or fire
Jun 20, 2017 | Vulcan VG36 Gas Kitchen Range
I have vulcan Double stack electric ovens 208v 3ph.what size breaker do I need to power each oven
I need to know the Power rating Example 5Kw or the Ampere Ex. 30A . What is the raring of each oven? The Breaker should be greater than the Ampere of your oven let say 120% greater.
Jun 11, 2009 | Vulcan Convection Oven - VC44EC-208-3
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Dec 17, 2008 | Vulcan 260L Gas Kitchen Range
Why won't my oven ignite? Vulcan model GC04c
i can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Jan 16, 2008 | Vulcan Convection Oven - VC44EC-208-1
Kitchen Ranges Logo
190 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
