Question about Samsung SPH-a660/VI660
Mike doesn't work. - Samsung SPH-a660/VI660
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
My Pride scooter bought in '97 doesn't run
Hello, my name is Mike.
Here is a couple areas that would cause this:
A faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors. Sometimes even if the meter is not dropping poor batteries can cause surges which would cause this. Sometimes you get lucky where you take key out, and let set for a bit. Then put key in with out depressing throttle. But that is rare this works. Most times it going to be a battery issue, or a faulty throttle pot. Best to have service place replace this if your not really mechanically inclined in electronics. Thank You , MIke.
Sep 19, 2011 | Pride Celebrity Xl 4 Wheel Scooter
Hi, These things have been happening for quiet some time and should have been addressed but weren't: Squeaking (loud), electronic panel doesn't work, sometimes the dryer doesn't work at all...
Hello, trgottlieb I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Jul 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I need the phone number for the Larry Myers dealer in Bridgeport, WV. I have tried the number given online (304-366-3311), and it doesn't work. Is there another number to call for service?
HI, Google search yeilded this address and phone number:
Larry Myers Subaru
750 Lodgeville Road
Bridgeport, WV 26330
(304) 848-6000
Hope that helps, Mike
Jun 21, 2011 | Hyundai Elantra Touring Cars & Trucks
Hi my name is Mike. I am a sales manager for a large chain of lease to own companies. I have a customer who says that the right speaker on his edison ed-8000k dual cd DJ system is not working. I have...
Mike,
In its most basic form, a sound system consists of a signal, amplifier and speaker. If there is a problem with any of the three - unexpected results can occur.
Swap the speaker with a know good speaker. If it still doesn't work, it is not the speaker. Change the signal. This is usually done by selecting a different line level input, ir connecting a different device to the input(s). Your device may not have the ability to do this. If you are able to choose a different input, and the problem still exists, then it is probably not the input, either. That leaves an amplifier problem. The amp could have failed naturally, or due to an open or shorted speaker connection, connecting the wrong impedance value speakers, playing at a very loud level, etc. Some amps have a fuse or circuit breaker that opens in many of these situations - your may or may not have this feature. If it does, there's a chance it didn't open before the damage was done though. Needless to say, if you replace the fuse or it doesn't have one and the problem still exists, it will probably need to be sent out for professional repair.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 21, 2011 | Audio Players & Recorders
I have 05 volvo vnl 670, isx cummins 450/500. keeps losing power, check engine ECU comes on knowbody seems to know what it is. they just keep replacing sensors.
I have a 2007 Volvo 670. The check vehicle ecu comes on. The fault code is MID 144 PID 191 FMI 5. THe truck won't go pass 1400 rpm, the speedometer doesn't work, the cruise doesn't work, the engine break doesn't work. I have to turn the truck off going down the road at highway speed for about 10 seconds and it'll go back to normal. Can anybody help?
Feb 16, 2010 | 2005 Volvo XC90
Samsung SPH-a660/VI660 Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
