Question about Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera
Memory card eject button
Hi! I'm hoping (and praying) you can help me! I'm having a problem with my camera, a Konica Minolta Dynax 5D. The little eject button next to the memory card slot doesn't hold down. I can insert the card, the camera works fine and reads from it, and I can press down on the button and remove the card. The problem is that the lid won't close because the button stays always out, loose, even with no card in. Help, please! and thank you!
  • 3 more comments
  • ama52978bb Sep 05, 2008
  • reking Oct 28, 2008
    I can not replace the card because the eject button when pushed down ejects the card. I have pushed the button down and inserted the card but the card won't go in all the way and of couse if the button pops out and when pushed ejects the card.
  • fatboyhilton Nov 18, 2008
    I have the exact same problem as Alves's memory card eject button. Please help us.
  • jsauers Dec 05, 2008
    exact same problem here, I'm almost ready to just break the little ejector off so that the door can close - it would make it a little bit more annoying to get the card out but you could still do it
    i also looked at removing the back cover of the camera but got scared by all the screws and what might happen when it lifts off, i.e. all the guts fly out and won't go back - no memory ejector is worth that!
  • brantontm Jan 28, 2009
    Same problem. Just happened tonight when I went to upload pics to my PC. The eject button pushes the card out.
  • 72 Answers
SOURCE: Konica Minolta Dynax 5D/Maxxum 5D turns itself off after first shoot
It sounds like that's the first black frame problem that is a fairly common defect with the cameras, so much so that Sony is repairing it for free, for more info, see:
http://ca.konicaminolta.com/information/20070202/01_en.html
then go to:
http://eservice.sony.com/webrma/web/index.do to set up for service.
Posted on Oct 20, 2007
SOURCE: Struggling to get bulb mode
go to menu, move over to wrench, select. then move down to ctrl dial set. select aperture. now go back up and get out of menu. now you want to select "M" on your right dial.,turn your clicker knob on the front right of camera, and there you can click to bulb. hope that made sense!
Posted on Mar 21, 2009
  • 411 Answers
SOURCE: cemera says unable to use card. even after i
contacts of the card reader,card clean asjust the contacts.
Posted on Apr 03, 2010
  • 11 Answers
SOURCE: I have a konica minolta
Try changing you card with other one and see what's happennig: if the camera is working properly then the card has issues.
CIAO
Posted on May 06, 2011
KingDWS
  • 1606 Answers
SOURCE: I believe I must get
Unfortunately Konica-Minolta stopped supporting their cameras in late 2010. So all of thier support and downloads no longer exist. You can contact a service center and they may or may not have a disk. This link goes to a list of repair depots. I don't know your location so I can't narrow it down more for you. I do not believe they made drivers for Vista so you may have problems even if we can find drivers.
I did a quick search for drivers online. Sometimes resellers will offer downloads from thier websites so it is worth a try. I searched using the following keywords"Konica Minolta Digital Camera drivers" I found a few but some of those are in the iffy category or the pay type. This link is to CNet which is legitimate so try this and see if it works.
http://download.cnet.com/KONICA-MINOLTA-DIGITAL-CAMERA/3000-18489_4-81440.html
You may be able to find the cd on ebay or craigslist so it may be worth looking there as well.
Posted on Sep 24, 2011
Memory card will not go in all the way and the door won't shut.
was it working before?
turn the memory card anyway and have a try - before check inside the memory card compartment with a flashlight if you can see the contacts at the bottom and insert the card corresponding to them.
Or try another card to exclude yours is not damaged or wrong type somehow....
Konica Minolta MAXXUM 5D Instruction Manual Inserting And Changing Memory...
Mar 07, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
Old pictures show up fine but new pictures show up very darkkk
two reasons for this are possible:
1) you changed the exposure compensation by mistake to minus something... - see below - change it again to +- zero:
Konica Minolta MAXXUM 5D Instruction Manual Exposure Compensation
2) you should have the ISO settings to auto:
Konica Minolta MAXXUM 5D Instruction Manual Camera Sensitivity iso And...
Jan 28, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
Strange grinding noise when turning on & off my minolta 5d
inside of the camera are some parts, that can be broken or loose see the diagram, and proceed with common sense. God bless you
Jul 21, 2012 | Konica Minolta Dynax 5D / Maxxum 5D...
Trouble installing the memory card.
Is this the original memory card? if not! and you recently bought one card, sounds like the right configuration but it is a bit to long for the camera body. I suggest taking it to a camera shop to make sure it is the right card.
Mar 30, 2012 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Hi, the flash card card-eject lever spring is broken and wont eject the card. u have to manually push the card in place and pull the card out. the lever stays up until u shut the card slot door.once the...
I have the same problemI think that the reason that the not record the image is that the card slot door is pushing down on the card eject lever and ejecting the card when the door is closedThe only answer I can think of is to shorten the leverdavidh
Feb 18, 2011 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Cemera says unable to use card. even after i
Apr 02, 2010 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Need to set self timer
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). To start the self-timer, press the shutter release button.
Sep 06, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Jan 20, 2009 | Konica Minolta Dynax 5D / Maxxum 5D...
Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera Logo
87 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
