Question about Refrigerators
Fridge shorts power out
can anybody help with a problem that i have with the fridge shorting my main supplies out. I think that i may have found the problem. at the back of the fridge there is some sort of timer switch, when i turn it around it shorts out at a certain point. the switch is located at the bottom of the fridge next to the black cylinder. the model of the fridge is an westinghouse silohuette frost free upside fridge/freezer. is it worth fixxing and if so is it an expensive problem to fix.
cheer micheal
  • 828 Answers
From your description it sounds like a short in the defrost heater circuit. It would normally be a repairable item. You may want to consider the age of the refrigerator before getting into the repairs.
Posted on Aug 24, 2008
Why won't it power up?
Kindly disconnect back light module & try power on , if fail try change any bulged capacitor ,then your VA output should have 5v, 12, & 24v if not present please change your power supply
Jul 19, 2015 | LG 60PS60 60 in. Plasma HDTV
NO POWER AT ALL
Hi
our tv set need to be serviced. Here are some tips:
1. Open main fuse. The fuse is clean but interrupted. You can try replacing it with one o the same value.
2. Fuse Blown or blackened. Short in the rectifier bridge or in the switching transistor. Out of the power supply: supply line rectifier (100/150V) shorted.
Sully
Sep 29, 2013 | Televison & Video
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
47 inch vizio blown fuse
i am having the same problem and my power light wont even turn on so i think it might be tht power fuse. Is tht what was wrong with urs?
Dec 18, 2011 | Vizio VO47LF 47" TV
No power
Yes, the power is working as well as the processor seems to start up the circuit but it ends up with a protect shut down. So it is possible there is some error due to a fault or short within the main board and this might require fault finding using the circuit manual.Remove power remove the main board and look for shorted main capacitors, shorted drivers or open circuit of fusible resistors which can help with fault finding.
Dec 12, 2011 | Epson EMP-TW10H Multimedia Projector
I have a samsung hln617w that just shut off on its own, I opened it up and found a 6.3amp fuse(round glass type) had blown. I replaced the fuse but every time i try the power button it make a noise like a...
Hi Eloy,
There is some short circuit further up in the power supply. You have tried what you could do. Let some Tv Tech do the job onwards. Or if you are handy with some basic electronics knowledge I could suggest something.
Good luck.
Oct 14, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Fridge short circuits power after a period of time
it needs a new defrost heater , can b a bit tricky to change
Jan 31, 2010 | Refrigerators
I replaced main power unit and and formatter PWB but I cannot keep tv on. It turns on, I hear some buzzing then a faint click followed by an immediate louder cllick and powers off alltogether? Need help...
If power supply is good and voltage measures out ok. Also check any relays or capacitors.If LCD, check caps, if projection, check bulb and high-voltage transformer and flyback with a voltmeter.
Capacitors are the most common reason for failure in today's electronics.
Nov 15, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Samsung TXN3298HF 32" Flat CRT is dead, please help
Hi I have a Samsung Tantus Dynaflat 32 inch flat screen TXN3298hf that all of a sudden stopped working...no power no nothing. We opened up the back and found that a 5 amp fuse had blow. This fuse regulates that power supply to the tv and can be found at the end of the power cord prior to the circuit board. Hope this helps.
Jan 22, 2007 | Samsung TXN3298HF 32" TV
Fuse keeps blowing
NEVER EVER replace a fuse and think that va fuse will blow all by itself. The fuses are there to protect the set from catching on fire incase theres a short inside the set. Now in some cases an intermittant short can work after you replace the fuse but if its burnt black or brownish, theres a short inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifyers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted
Sep 06, 2006 | Panasonic CT-32SX12 32" TV
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
