Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Getting hair out of gears
How do i get to the belt gears?
  • pameloobrenn Aug 27, 2008
    I cannot get dog hair out of bottom (clear section) I can take them out of brushes, but they also congregate in the middle - which is unreachable.
  • 107 Answers
Best way is with a screw driver and needle nose pliers. remove belt and brush first.
Posted on Dec 08, 2008
The motorized brush on my DC35 no longer turns. I cleaned the debris from the brush but it still won't turn. The belt is in great shape but the gear is physically hard to turn. How do I fix it?
After removing the screw in the centre of the brush bar drive gear, gently lever the gear away which will reveal a possible build up of hair behind.
Jun 22, 2015 | Dyson DC35 Multi-Floor Cordless Vacuum...
Kenmore canister power head not working?
Without more info, I would investigate the drive belt, make sure the beater bar is free to spin (no hair or carpet fibers twisted onto the moving parts), and then check that the power is getting to the motor of the power head. Most often it is hair/fibers that collect around the ends of the beater bar. This causes the belt to stall, heat up and stretch due to the drive motor shaft spinning on one spot because the belt can't move. After removing twisted hair/fibers, you probably only need to replace the belt.
Aug 08, 2014 | Kenmore 25614 / 25615 Progressive Bagged...
Dyson making loud noise
Not sure if this will help but mine sometimes make a loud noise as well and its usually due to hairs stuck UNDER the belt in the motor area. Get some sharp skinny scissors and long skinny pliers and get under that belt, cut the hairs and use the pliers to pull out those hairs. That noise is usually because too much hairs stuck under the thing that turns the belt and the belt cant spin so it makes a lot of noise. When i do this it solves the problem of noise, but eventually hairs will collect in there again and make the noise again so i just take the hairs out again and problem solved.
Dec 14, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
The turbo brush attachment on my bissell cleanview helix suddenly wont spin. I bought this vacum a month ago. there is nothing wrong with the vacum otherwise.
The turbo brush may just need to be cleaned. If hair or other large debris gets wrapped around the brush, it can prevent it from spinning. Since the top of the turbo brush is clear, you can look in and see if there is a lot of hair wrapped around the brush. If so, you can open it up by removing the two screws on the bottom of the brush and popping the clear cover off, then cleaning all the debris from the brush (scissors work well if its hard to get dog hair off). Be careful to see how the brush goes back together as you take it apart.
If cleaning the brush doesn't fix it, the belt might be broken. As you're looking at the top of the brush, there is a little belt that goes from the brush itself to the large blue/green gear (it's red on some models) so that if you reach your hand in and turn the gear, the brush should spin. If this belt is broken or missing, it will need to be replaced. You can probably find a replacement belt online, or you can order a whole new turbo brush from the Bissell website for $24.99.
Feb 04, 2011 | Bissell Cleanview Helix Deluxe Bagless...
HI I have a Bissell Pet Hair Eraser it has a very loud high pitched squeal, I have removed the belt & cleaned it with no effect. Is there something else I cn do? Thanks Joe
The belt may be stretched out and therefore, no good. You can try roughing up the surfaces the belt rides in with some 150 grit sandpaper. That may do the trick
Feb 02, 2011 | Bissell Upright Vacuum - The Pet Hair...
My floormate is not suctioning very well. Tech support told me to take out the brushes and put them back in and this helped for a little bit then it went back to not suctioning. deb
When you took the brushes out, was there hair wrapped around them? Sometimes they just need to be cleaned off. When you take them off, there is a belt they connect to that also goes around a gear -- make sure the belt and gear don't have hair wrapped around them either.
Hope that helps!
Aug 28, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hair getting stuck in the belt drive area causing beater to skip
Hair,string, tinsel, etc. have always been problems for rollers and belts. You will have to remove the hair. It can often get stuck at the ends of the rollers also and keep the roller from turning. I usually remove the roller and clean it using a screwdriver, knife, etc. to remove the hair. the cleaning can be done while the roller is still on the unit by turning the unit over although this may not offer as much free access to the roller. Of course, removing the roller means removing the belt and if you are not up to this (I don't know how handy you are), I would try to remove the hair with the roller on. If you do this, be careful not to put any nicks in the belt. Good luck!
Mar 13, 2010 | Dyson Vacuums
Dc17 -too much pet hair around the belt gears
I was having the same trouble and it was driving me nuts.  I tried cleaning and it did not work.  Then I tore the brush assembly off and looked up into where the little tooth gear is.  I saw something that did not look right.  There was a silver roller bearing laying down below the assembly.  I got some tweezers and found it was not attached to any thing.  I then cleaned out the pet hair and saw a spot where this roller goes that takes the slack out of the brush. It is a pain and takes alot of trying with pliers and prodding  with a screw driver, but I got the roller back where it goes.  It does not attach very solidly, but I put every thing back together and it works great so far.  It is a definite design flaw.  I found that you have to keep the main unit on  the floor when the brush is running.  Do not do stairs or pick it up and do couch cushions, that is when the bearing breaks loose.  Dyson needs to figure out a better design for this.  I was lucky to figure it out, but it is very hard to get to.  Again never pick up the unit when the brushes are engaged.
Jun 05, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Go to a DC14 there is a reason why Dyson calls it the Animal. It's ment for all the pet hair and things like that, listen to what Dyson recommends you, they know their products well.
Apr 12, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
60 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
