Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hi-speed USB device plugged into non-hi-speed USB hub
I'm Shiva from Hyderabad, India. I'm using P4, 3Ghz & 512MB RAM system with 512MB RAM.
I've connected a USB device ( a receiver for IP Dish TV ) to my system nd was working fine. Later coz of some probs with my computer, I've formatted it. nd now when I connect this USB device again, it's showing an error sayin. "hi-speed usb device plugged into non-hi-speed usb hub" nd " connect it to a USB2.0.." somethin like that.
When looking for support in microsoft.com, I read an article (http://support.microsoft.com/kb/312370/en-us) acordig to which my "Windows XP does not include support for EHCI host controllers" and has to install latest version service pak.
I've installed Windows Xp Service Pack 3 nd surprisingly the problem still persists. Can any body help me out in this regard. It's URGENT.
Thanking you
Regards
Shiv
  • 702 Answers
Hi Shiva,
Did you try to boot into your BIOS and check the settings for your USB port? Often you can set the compatibility mode there.
Secondly, try to connect the usb device to different USB ports on your PC, they might not all be connected to the same controller (front or rear for example).
Jules
Posted on Sep 03, 2008
A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Aug 09, 2010 | A4tech Viewcam PK335 Webcam
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Portege 3490CT problem with external CD-RW backpack
This is nothing to be concerned about it the message is just informing you that you are plugging a USB 2.0 device into a USB 1.0 port, which means that it will still work but will run at a slower rate than it would if you had a USB 2.0 port
If you want to turn off this error message follow the instructions here
http://support.microsoft.com/kb/835967
I hope this helps
Jan 20, 2009 | Toshiba Portege 3490CT Notebook
Ipod wont show up on itunes
When you have a high speed device like the ipod plugged into a non high speed usb hub, all that means is that it will take the ipod about twenty times longer to load up under itunes then it will using a high speed port. Try connecting the ipod to a different usb port and see if that one is a high speed port (if it is, it will most likely have 2.0 written beside it, and if it does not have it, when you plug it in, it will tell you if it is a non high speed usb port. The same message should pop up. Try all of the usb ports on your computer. You should have at least 1 high speed port.
Nov 08, 2008 | Apple iPod classic MP3 Player
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Usb
hi,
i am from hyderabad, india.
i have brought JVC840.am6 PCLi360 Model JVC webcam ,
The problem with this is drivers are not get fully supported and these drivers are not certified logo with windows XP SP2.
but these drivers are with webcam for the usb support and installation.
please get me help through this..
Thank you
Jul 02, 2008 | Computers & Internet
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea? every time i plug a usb in to my computer it comes up that this device can perfom faster on a hi-speed usb port
This is not an error it just means that you are plugging in a usb 2.0 device into a usb 1.0 port. The devise will still function normally just not as fast. You could always add a usb 2.0 pci card to your computer.
May 05, 2008 | Samsung YP-K3 MP3 Player
Mercury MOTHERBOARD KOB P4M266 NDFSMX
I AM NOT HAVING MOTHER BOARD CD TO INSTALL HIS DREVERS AND HOW TO DOWNLOAD HIS DRVIERS BY INTERNET
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Webcam not working
Hi speed USB Device attached to non Hi Speed Hub.... this message appears because the USB hub controller is not updated. Try to download USB 2 driver from the following. http://www.softwarepatch.com/tips/usb2-driver.html
Another application already using webcam--- for this error message... try this.. right click my computer. Properties-> hardware tab. -> device manager. check any abnormal marks like a yellow circle or yellow question marks in the cam . also check the COM ports.
Dec 29, 2007 | Microsoft Office Outlook 2003 for PC
Samsung yp-k3
1. You can download the software from the samsung website
2. The usb message is nothing - it is just telling you that you have a USB 1.1 hub but you well get better transfer speeds using a USB 2 hub, or you can connect it to a usb port directly
Oct 22, 2007 | Samsung YP-K3 MP3 Player
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
181 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
