Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Dell monitor. When i turn my monitor on it flashes off. I can see a faint screen. I googled the problem and it brought up fixya.com. I read one of your posts where you said the lamps had gotten broken. But i couldn't find where to get the lamps online. I am assuming that they are bulbs? If you have a link for that it would be great
  • Reebtraf Aug 26, 2008
    Monitor shuts off after 2 seconds following power on.
    Brigadier General:
  • 6,966 Answers
Sorry for the very long delay, it is just now that I saw your post. In any case should you still be interested, perhaps this may be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
A125 monitor is dark
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Toshiba Satellite Computers & Internet
When i turn on pc monitor flashes then goes black. i can see faintly that it is on.
Oct 11, 2012 | Toshiba Tecra A8-EZ8312 PC Notebook
Monitor fails to activate. When turned on: - green light shows for a second or so, screen flashes - green light turns off and screen goes blank - after several second this repeats Monitor now stuck in...
You can try replacing the power supply/inverter board or troubleshoot it down to component level.
It can be the fuse, transistors, bad solder joints, bad lamps assembly, etc.
See pictures here:
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20E173FPb/
Replacement board: http://www.lcdrepair.us
You should also read my guides:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 22, 2011 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell 173FP - black screen - green flashing power LED
It can be bad fuse, shorted trnaistors inthe inverter circuits, bad caps, transformer. See the pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Post back what you find so we can guide you further.
Mar 10, 2010 | Computers & Internet
Press power on... screen flashes on (blink), then goes blank and power button flashes
dpelrod727, Yes, the "switch-mode-power-supply" is in "partial" or "full" SHUTDOWN mode. Reconnect E172FP to a fully booted KNOWN good PC with the win-desktop as the displayed screen. Check with flashlight to see if your LCD panel is both BLACK and BLANK, or just BLACK by holding a bright flashlight 1" from screen at different angles even though the screen appears to be blank. If very faint image of desktop is seen then your SMPS is still half alive. Here are your options in either case. 1. Trade in for new. 2. Try Dell for a cash+old swapout for a Refurbed unit. 3. Check out www.ccl-la.com/badcaps, www.badcaps.net, www.lcdparts.net, and YOUTUBE long video clips dealing with LCD monitor disassembly and LCD repair. could be helpful in making decision on what to do. I'm 12fixlouie If this was helpful rate on fixya.
Nov 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Dell monitor 2005FPW keeps on flashing
I was having the same problem.
I solved it by replacing the two 47µF capacitors on the power supply/inverter board.
I actually removed all the capacitors (around 13) and all checked out fine except for the two 47µF.
I forgot to take pictures or even write down the capacitor label on the board.
They are located close to the logic board connector
Feb 05, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
48 people viewed this question
Alun Cox
