Question about Sony Cyber-Shot DSC-T1 Digital Camera
Black screen when on camera or record mode, the screen is black. It'll take a picture and/or record but all in black. I thought the camera needed charging but that didn't change anything. I tried to view/change all the settings but still nothing. Any solution? Could it be defective? Please advise on how to fix or if it's even possible at this point. Thanks!
  • razsrq Jan 04, 2009
    Had the same blank/black screen issue on my DSC-T1. Per the link below, Sony walks you through a 3 minute test and if you are experiencing issue as described, they will fix it for FREE until March 31,2009. (Small $15 charge for shipping)
    Thank you so much to the person listing the link below. I am sure you save me a lot of $$$.
  • Mini Minx Jan 10, 2009
    I have the same problem with my T1 camera..... but I'm in the UK.
  • 10,594 Answers
Your DSC-T1 has problem with CCD Imager and Sony will repair it free of cost. Please click Sony website and confirm camera symptoms and get details to proceed further.
Regards,
Posted on Aug 24, 2008
  • Shahid Electronics
    Shahid Electronics Aug 27, 2008
    I suggested best solution for you, at least it deserve fixya rating.
Canon SD 550-- sensor problem? Bought 3/2006 and have had no problems. Suddenly, LED screen went black--shows nothing and cannot take a picture altho will flash and record black picture. Shooting...
The shutter of the camera is not opening that is why every picture taken is recorded black. It is a mechanical problem and probably has nothing to do with the sensor. Not very expensive
Aug 30, 2008 | Canon Cameras
BLACK SCREEN IN PICTURE AND RECORD MODE
Your camera has problem with CCD Imager and Sony will repair it free of cost. Please confirm camera symptoms and details on Sony Website to proceed further.
Regards,
Aug 23, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
BLACK VIEWER SCREEN WHEN IN CAMERA OR RECORDING
Regards,
Sony camcorder DCR 265E
i think you are in picture mode when the screen mode is changed then it will appear black and recording cannot be done beeing in that mode you have to change the screen mode into recording mode and then continue
May 25, 2008 | E.Digital Sony DCR-TRV265E camcorder Pal
Black screen/record/playback.
lcd ribbon is bad have to send in for repair
Dec 26, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
NO PICTURE
I had this with my Panasonic NV-DS60. I thought it would be the ribbon cables not making good connections from the camera lens electronics because I had a similar problem with another camera. So I took the whole thing apart and disconnected and reconnected the ribbon cables - unfortuantely this didn't work! So I thought there may be another connection I couldn't see so I tapped around the lens area with a hard object (tip of a screwdriver) and it worked! It may be well worth you tapping the case in this way (without pulling the camcorder to bits) on the top, about an inch back from the front of the lens a couple of times. I'm not an expert, but it worked for me! Obviously, don't hit it hard enough to damage it. Good Luck
Nov 26, 2005 | Quasar VM-L153 VHS-C Camcorder
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Sony Cyber-Shot DSC-T1 Digital Camera Logo
57 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
