Question about Philips DVDR3455H/37B
Do not read DVD anymore
All of a sudden my PHILIPS DVDR3455H does not read DVD anymore and give the "Disc type not supported" message. I have tried different DVD I often use coming from different sources and I get the same message.
  • pave Aug 24, 2008
    I have same problem with LG DR4812W DVD recorder. the only type I can get to work is a 4X DVD-R but cant buy these anymore
  • 8,596 Answers
Unplug/replug try again
Posted on Sep 04, 2008
My Philips dvdr 3450H if i insert a origial dvd says (not supported disk type) HDD work correct only won t read dvd what can i do? thank you
You are not alone...Some DVD players especially Philips wont read the DVD s and
then it show no disc..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc has problem laptop does not read either..
HDD works independently and no relation to DVD reader..if your set has still under warranty ,consult to service they may replace the LASER EYE.. ("cross your finger ! " )...
Just in case,quick remedy ,I recommend to buy a "wet DVD/CD laser cleaner " from any store.it is available even in Walmart..And clean the laser eye at least twice..
YOUR DVD itself should be clean and finger prints free as well....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 01, 2011 | Philips DVDR3455H/37B
DVDR3455H/37B
What is the exact model of your unit? Wait a sec I will give you one.
Sep 27, 2008 | Philips DVDR3455H/37B
Hi, my Philips DVDR3455H/75 DVD/Hard disk doesnt
THE DVDR3455H HAS A COMMON PROBLEM AFTER A FEW YEARS THE HARD DRIVE GO BAD, IT WONT BOOT UP
99% OF THE PROBLEM WITH THE PHILIPS DVDR3455 IS THE HARD DRIVE.
IT WILL KEEPING REEBOOT OR IT WILL HANG ON THE PHILIPS LOGO.
IT IS NOT A FIRMWARE PROBLEM IT AHARD DRIVE PROBLEM.
ONE THING YOU SHOULD KNOW, IF THE HARD DRIVE IS BAD YOU WILL NOT BE ABLE TO UPGRADE THE FIRMWARE IT WILL NOT READ THE CD OR DVD DISK.
AT THIS POINT IT NOT LOOKING FOR A FIRMWARW DISK BUT IT LOOKING FOR THE BOOT UP SOFTWARE.
OR THE LOAD CD WHAT PHILIPS CALL IT.
SOLUTION REPLACE THE HARD DRIVE WITH THE LOAD SOFTWARE INSTALL ON IT.
THE HARD DRIVE IS SOLD ON EBAY JUST LOOK FOR DVDR3455H YOU WILL FIN NEW DRIVE READY TO INSTALL THAT WILL FIX YOUR PROBLEM.
Nov 03, 2009 | Philips DVDR3455H/37B
Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Apr 02, 2009 | Philips DVP3960
DVDR3455H cannot bootup
I had the same problems with my DVDR3455H, and have finally have it working again, although I don't know for how long.
First, the DVD drawer not opening is a common problem, reportedly caused by a magnet not letting the spindle drop. The solution I've seen elsewhere is to always keep a blank DVD in the drawer; it usually has enough weight to help the spindle disengage from the magnet holding it up. By the way, there is an emergency release slide on the bottom of the unit if it still won't open.
More important is the hard drive. I was finally able to get the unit to work after connecting the hard drive to a PC using a USB attachment and running a full format (NTFS) on the drive using SwissKnife. That actually failed after eight hours, but I was then able to run a quick format through Windows Explorer. I then put the firmware on a CD-R using Nero Express, put it in the drawer and powered on the unit. After a week of repeated LOAD/COPY/BOOTs after running quick formats on the hard drive, this time I got the FLASH1 message. From there, it was just a matter of following the on-screen menus.
I'm thinking it may just be a bit of luck, but I think the full format was the key. Note that this is still the same hard drive, so it could still fail again. I also ran Check Disk looking for and fixing bad sectors, prior to my final full format.
Hope this helps.
Mar 15, 2009 | Philips DVDR3455H/37B
Replace/Upgrade Hard Drive in Philips DVDR 3575H DVD Recorder
email this person at krystle913@yahoo.com for a replacement hard drive for the philips DVDR3575H OR DVDR3575H/37
also can replace hard drive in the philips DVDR3455H OR DVDR3455H/37
Oct 13, 2008 | Televison & Video
My dvd player
You didn't hear it from me, but I've heard you can close the disc tray with no disc in the tray, and enter 138931 on the Philips Remote and when the region code msg displays, change it to 0. Warning: You can only change the region code 3 times in the history of the player, and then you will no longer be able to use the feature. But, you didn't hear that from me.
Sep 17, 2008 | Philips DVDR3455H/37B
Rec from hdd to disc
Only use one of the disc types that is listed in the manual that they have actually tested on unit. If the HDD recordings were made in HQ mode, then you will only be able to fit a one-hour or less recording on a DVD. You cannot reverse this at this point. For future HDD recordings, set the record mode to 4hr or higher.
Jul 20, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Playing recorded dvd on other devices
you have to finalize disc before try it in other players.
Aug 31, 2007 | Philips DVDR3455H/37B
Philips DVDR3455H/37B Logo
219 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
