Presario A900 not showing cd drive in my computer and does not work when a cd is put in
  • trav0007 Aug 24, 2008
    Its actually a A905TU. would it still be the same answer to fixing.
    Thanks
    Sergeant:
  • 226 Answers
There are 4 different models of the A900 ( ED, EO, ES, and ET ). Select your model from this page
and select Software and Driver downloads from the following page. Your updates for the model you selected in the first will come up. I suggest install each and every one of those updates.
The reason I say this is because the Sony Vaio has a problem in Vista that disables the CD/DVD until a certain update is installed from their Support site. I'm not saying that is the same situation in your case, but the possibility does exist. Many of the updates will ask you to reboot the computer and for the sake of clarity you probably should reboot when it asks you to, so you need to write down or remember the support website for your model. Bookmarking the page will do the trick and I suggest you do that.
I believe that once you have completed these updates, you will be relieved to a CD/DVD on your computer again, I hope. I know this has worked several times on my Sony Vaio.
Posted on Aug 24, 2008
  • Ravel Lively
    Ravel Lively Aug 24, 2008
    Just select your model from the page that I gave you, make sure you are using the correct downloads and updates, else possibly bad things could happen.
  • Ravel Lively
    download page for your 905TU
    If you are using Vista, make sure you get the vista download and if you are using XP, then make sure you get the XP downloads.
    Save all downloads to a download folder that you should name " A905TU " ( without quotes of course ) to remind you that these downloads are the updates for your computer software and hardware. I recommend getting all the downloads before installing any of them. Do the Bios update first and the Intel chipset driver update after that, before any of the other updates.
    Remember in the future that model specifics are VERY important for the technician to help you. It would have been very easy for someone to have given entirely wrong information basesd on your initial posting. Glad you were able to come back quickly and correct that information.
My CD Player for a [Compaq] Presario V3000 hasn't been working. It worked fine less than a year ago, then it stopped working. My Computer doesn't show the CD icon any longer, not even Device Manager seems...
It will cost about $30 to buy a brand-new CD/DVD reader/writer.
Any computer-store technician can easily "manually" open your current drive, and remove the CD/DVD media.
Dec 14, 2010 | Compaq (120192-B21) CD-ROM Drive
Which button do you use on a compaq presario A900 laptop do you press to switch to external monitor
Each model are not exactly the same, it is combination keys, Fn and either F4, F5, F6, F7, or F8.
May 10, 2010 | Computers & Internet
How do i play a dvd and a cd in my compaq presario FS7600?
Put it in the CD Drive - open My computer and left click on it if it doesn't auto-start.
CD Drive may not be working if can't read from My Computer
Apr 04, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
HP Compaq notebook with a philips dvd-ram won't read
If you can see the CD Drive icon in My computer, it shows that at least Windows recognises the drive. If you are unable to see the drive listed in explorer (not the cd name but the actual drive icon), then please post a reply.
Other than that, you are describing what I think may be a faulty drive. If you open the case, check to see if the drive cable is in good contact with the connector and motherboard.
Feb 10, 2010 | HP Compaq Presario V6000T Notebook
My laptop Compaq Presario A900 can read Blu Ray?
Here are the specs on your drive. Does not look like it will read Blue-Ray
Optical drive type
A961TU: SuperMulti 8X DVD±R/RW with Double Layer Support
Oct 25, 2009 | Compaq Computers & Internet
Dvd rom reads only dvd not cds
hi frnd...
try finding out the name of Ur DVD rom.. it will be available in the DEVICE MANAGER.. to access device manager just type DEVMGMT.MSC in RUN option... once u have located the name of the DVD drive .. just go to the DVD drive vendors site and download the firmware of the dvd drive and instal it and restart ur system it will work fine.. while installing the firmware the LED on the drive blinks...
Oct 01, 2009 | Computers & Internet
Laptop not show cd or dvd when i put it
Well, for starters, is your cd/dvd turned on in the bios.  Some but not all computer have a setting for this.  If your cd/dvd drive is removable, shut down the computer, remove the drive.  Reboot the computer and shut it down again.  Then reconnect the drive and start the computer back up.  This will make sure that if your drive is working, windows will redetect it.  You can check device manager to make sure it is not disabled.  If none of this works, you may have a bad drive.  If you really must reinstall windows, you can get an external cd/dvd drive pretty cheap on Ebay.  Just make sure you go into your BIOS setting and change the boot menu to external drive.  I hope this information helps.
May 30, 2009 | HP Compaq Presario C700T
Ok....my cd-rom drive is not reading the cd's?
first remove the cd and restart the computer and see if the E:driver if it is not let me know if it is there put the cd and try it again
Apr 14, 2009 | HP Compaq Presario V2403NR Notebook
My screen showing a vertical line
Replace the laptop under warranty. No point trying to fix the error and voiding the warranty.
May 25, 2008 | Compaq Presario Notebook
Screen or computer problem?
Is it a laptop? conenct it to a monitor, see if that works, then u know it might be the LCD.
Mar 06, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
