Question about Bosch Kitchen Ranges
Door to bosch oven does not close properly - Bosch Kitchen Ranges
  • Anonymous Jan 12, 2009
    My Bosch HGS7282U Range door does not close completely and top front of oven/range gets very hot when using oven. The door hinge detents in closed position before door comes in contact with top door seal.
  • 639 Answers
I'm Neil
No problem
This is a fire hazard!
You will have to call service this time!
Thank You for asking!
Neil
Please rate my solution
Posted on Aug 24, 2008
3 Suggested Answers
SOURCE: Oven Door will not close properly
Cleaning lady knocked the hinge springs off my oven door, so i'm
trying to figure out how to reattach them.
On My GE44 stove, there is an adjustment for the spring, where it attaches at the bottom (inside the stove), there are several holes the spring can be attached to. (I found his described in a little "Pub. No. 31-0773/SR4034 paper in an envelope taped to the back of the stove)
Doing this while the stove is installed may be a challenge though,
(that's basically the problem i'm having) it would be easy if the stove was upside down.
Posted on Jan 14, 2008
SOURCE: lofra five burner gas cooker, oven door not closing properly,
I had the same problem and took the door apart. The hinge has a spring inside which is held in place by a long rivet. The metal of the rivet is too soft and it bends and snaps. You cannot get a replacement hinge anywhere. I even tried Italy and France. Lofra won't speak to you by e-mail or phone. The next thing that happened was the element disintegrated in the ovan. These are the worst cookers on the market.
Posted on Dec 12, 2009
I have a Bosch wall oven in my unit but no user manual. The number on the door is bosch hbe632uau/03. Is it ok to close the door when using grill function or will the glass blow out?
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
Oct 19, 2015 | Bosch Ovens
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Good afternoon. Microwave oven after turning a few seconds an error H95. What could it be? Thank you.
Hi d_zolotov,
the solution is to close your microwave's door properly,
this error occurs when the microwave's door is not properly closed.
i hope your problem is solved
look at the picture below :
Feb 13, 2011 | Bosch Microwave Ovens
Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Jan 04, 2010 | Bosch Ovens
Bosch HDS7282U oven door won't close properly.
I am a old bosch repairman and i know for a fact that the door can be fixed. tighten the hinges with 3-4 washer on both hinges. nyc can fix this problem . if your door is really bad then both hinges has to be changed. but sometimes the old hinges willdo the same after awhile.
Dec 20, 2009 | Bosch Evolution Pro-Style 700 HDS7282U...
Bosch double oven, the bottom door won't close all the way
This requires door hinges to be replaced,relatively simple job & parts cheap.Best buy parts from Bosch direct .
Mar 15, 2009 | Bosch HBL 5056 Electric Double Oven
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Nov 21, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Kitchen Ranges Logo
180 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
