Question about Pioneer GM-X324 Car Audio Amplifier
Amplifier won't turn on
My amplifier won't turn on anymore, I checked the fuse and it's still good but it won't power up anymore
  • dcqcca Sep 08, 2008
    hello I have a GM-X324. my problem is that I left hook, one months
    after he stopped walking worse the light flash power any worse over
    checker but it's correct
Hello I have a GM-X324. my problem is that I left hook, one months after he stopped walking worse the light flash power any worse over checker but it's correct
Posted on Sep 08, 2008
  • 631 Answers
You need to confirm that you have voltage on the B+ and ground terminals and have a good ground.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If all of that checks out, the amp probably has an internal fault (blown parts, broken connections...).
Let me know if you have any other questions.
Posted on Aug 24, 2008
My stagg amplifier doesn't power on anymore, just
Internal power transformer or rectifiers. Could also be main power transistors.
Apr 20, 2012 | Audio Players & Recorders
I accidentally wired the 12v wire to my ground terminal, and the ground wire to my 12v terminal. A little poof of smoke and the amp won't turn on anymore. Checked my fuse and power supply, all is fine. ...
Hi
It look like you burned the power supply in the amp if the fuse is ok
there is a circuit that protect the amp and its possible that it burned
this should not be too expensive to be fixed
ecrdn@yahoo.com
Jack
Oct 19, 2010 | Jl Audio 300/4 Car Audio Amplifier
My Faroudja DVP 2200 isn't working. It won’t turn on anymore. I removed the cover and checked the fuse – and it was fine. I am not sure is there is another fuse. I had some previous issues where it...
i would check ac plug change it if you could it probably had a short and maynot be visible also some fuses made be hidden on underside of board so check good you could overlook it easy
Aug 27, 2010 | Electronics - Others
I accidentally plugged my 110V amplifier to 220V outlet.It has no power anymore.what possible solution for this. Thank you very much. Do I need to replace the rectifier in it's circuit?
Hi and welcome to the site,
Initially, on a completely dead Sony TA-N9000ES, primary suspects to be checked would be:
  • 8A F1 fuse;
  • primary winding of T1 transformer;.
  • fusible resistors R816, R817 and R818.
Good luck and thank you for asking.
Jul 13, 2010 | Sony TA-N9000ES 5-Channel Amplifier
MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Jun 03, 2009 | MTX Thunder 421D Car Audio Amplifier
Wont come on
What won't come on? Is this a radio that won't come on or an amplifier? If it is a radio not turning on, check all radio fuses (both at fuse panel and under hood). If these are all good and the radio still doesn't turn on, then you'll need to remove the radio and check power behind it.
If you have an amplifier that isn't turning on, you need to first check power on the fused power wire coming from the battery. You can use a 12 volt test light (available from an auto parts store) to check for power at the amplifier power connections. Test the 12v constant power and then the 12v remote turn-on power. If either of these are out, check fuses on the main and make sure the radio is delivering 12 remote turn-on power. If you are still having difficulty, please see a professional car stereo shop. They will be able to diagnose the problem usually in less than 1 hour for a small troubleshooting fee. Hope this was helpful.
Sep 28, 2008 | Pioneer Car Audio & Video
My amp is not powering up anymore
take the amp out the trunk and connect directly to the battery, use a jumper wire for the remote from the constant power 12volt , if the amp fail to turn on it may be damage. check the fuses and look for any burnt connection.use a test light to test for power at the connection.
Aug 30, 2008 | MB Quart RAA1000 Car Audio Amplifier
Amp randomly comes on and off
You may have an intermittent power problem. You will need a schematic and a multimeter to the the power supply voltages in the amplifier.
Sep 07, 2007 | MA Audio M1889I Car Audio Amplifier
My amp isn't working anymore !
make sure you have power, ground, and turn on lead. if you have all power the power supply needs to be repaired
Nov 20, 2006 | Jl Audio 500/1 Car Audio Amplifier
Pioneer GM-X324 Car Audio Amplifier Logo
113 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
