Question about Olympus Camedia D-390 Digital Camera
Reset I can’t remember which settings I’ve changed. How do I reset my camera to the defaults?
    Master:
  • 852 Answers
There is function called “Mode Reset” in the camera menu. Choose “GO” then press “OK” to reset the camera functions to the default settings.
Posted on Aug 31, 2005
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
Rz30n cammer
here is the link to the user manual if you need it; http://bssc.sel.sony.com/BroadcastandBusiness/docs/manuals/snc-rz30nuserguidev2.0.pdf or http://bssc.sel.sony.com/BroadcastandBusiness/docs/manuals/usesguidesncrz30nv4.pdf check page 25 (top left) for reset to default instructions (you have to read back a couple of pages to find the menu they are talking about) - there is however no mention of any password issues when you do this. If you do need the password to carry out the reset procedure, then I think you need to contact Sony - the camera is expensive enough that they should help; http://bssc.sel.sony.com/BroadcastandBusiness/info/contact.shtml Hope this helps:)
Jul 15, 2007 | Sony SNC-RZ30N Network Camera
How to go back to default settings of my router because i can't connect anymore after i log in the 192.168.1.1 i think i have change the setting and after that i cant access anymore in my wireless...
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Aug 04, 2011 | Linksys Wireless-G Broadband Router
Network security key
Aug 04, 2011 | Belkin F5D7234-4 Router
How do you reset your router password if you have forgotten the old one?
One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you’ve changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
Jun 24, 2010 | Cisco (AS535-4E1-120NP-) Router
Won't stay in manual mode
Go to your menu settings and find the setting all to default, menu reset, or factory settings, or something like that.This will reset all settings back to the way it was from the factory or default. Then you can set what you want. Different modes will have an effect on your settings and can change according to what is set.
At this point it is a good idea to read your user manual or you can go to this link: Menu Reset Nikon D100 This camera has two banks of memory, remember that as well.
Nov 09, 2009 | Nikon D100 Digital Camera
I locked my keypad
sorry but u ve to give it to the nearest phonerepairshop so they can reset that code to the default one 12345
cuz even if u try to reset the phoen manuly its will ask u about th security code that u ve already changed it !!
plz do rate this post!
Nov 29, 2008 | Nokia 1100
DCS reset
Push the reset button on the back of the camera
Oct 05, 2007 | D-Link Express DCS-900 Network Camera
ALL RESET
The ALL RESET function works two ways. When it is set to ON it restores the camera to the default settings once the camera is powered off. You can still put in custom settings, but they will be reset when you turn the camera off. When it is set to OFF the camera remembers the settings you have entered. For example, if you want the camera to always start up in the 3:2 aspect ratio you would turn ALL RESET to OFF and then select the 3:2 quality setting. The 3:2 setup will be there every time you start the camera up until you set ALL RESET to ON. When ALL RESET is set to OFF the camera will accumulate all of your setting changes, so it is recommended to reset the camera occasionally.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Camera reset
The D-390 allows you to choose if you want the camera to retain your settings or to default the settings. In the camera menu, there is a function called “All Reset”. If the selection is ON, the camera will default all settings each time the camera is powered on/off. If the selection is set to OFF, the camera will remember all of the settings that have been made.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Olympus Camedia D-390 Digital Camera Logo
125 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
