Question about Toshiba Satellite P205-S6287 Notebook PC
Satellite recovery what button do i have to push in order to start pheonix recovery
  • 813 Answers
Do u have recovery cd of laptop then u can recover if u not have then u have go with professionl repairer u have fromat your laptop
Posted on Aug 24, 2008
My Hipstreet Pheonix tablet by Google willnot power up after pushing start button Screen just lights up white.
sounds to me like it has a catastrophic failure. See what the tec. shop has to say.
Dec 18, 2014 | Tablets & eReaders
I have a toshiba satellite l655d-s5093 with windows 7 and it shows pxe-mof exiting intel pxe rom... no bootable device -- insert boot disk and press any key. any help to restore my computer? Thanks
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally.
IF THAT FAILS, try F-8 during pre boot, try to get to safe mode, or F12 to enter restore /recovery. After each try cold start, remove battery during this process.
Nov 09, 2012 | Toshiba Satellite L655D-S5093 Laptop
The phone does not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times before switching off.
Here is your solution read carefully and do it
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link X3 file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gif Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 13, 2011 | Nokia X3 Cell Phone
I got the toshiba recovery media disk that i needed but i cant get them to work!!!
Howdy ,
Sounds like you need to change the order in your setup.More than likely it is set to the c drive as number one and it needs to recognize your DVD/CD drive first so the recovery disk will boot up.When you start your laptop there will be a message telling you what button to push to get into setup.You may be able to use your mouse but if not you will be using the arrow keys and return key and y n keys.Most of these setups have tabs across the top.Open each one and look for boot sequence,highlight CD/DVD ROM and click your plus sign to bring to number one to be checked.
There is another way to do this if you still have an operating system.There is a partisan on your c drive that has a recovery option. Hold down the power button for 10 (ten) seconds and when it turns off hold the zero key and hit the start button.Keep pressing the zero key until you here beeping then you can let it go.The next screen will be a warning screen,select yes to continue , Select recovery of factory default software.Click next and Select recover to out-of-box state. Click next again to start recovery.I did this on my Toshiba and it worked great.dleemacc.png
Jun 06, 2011 | Toshiba Satellite L305D-S5974 Laptop
Where can I get/download free restore dics for my Toshiba Satellite a-135?
Theres restoration discs and then theres the original operating system discs,restoration discs only work under certain conditions far better to formatt and re-install operating system
Mar 14, 2011 | Toshiba Satellite A135-S4527 Notebook
I have this T5048 Emachine and its been great for the last 5 or more years but i just recently upgraded my memory to 2GB and want to perform a system recovery cause it will perform better after a recovery...
Turn the computer on, install the Recovery Disk in the optical drive. Give the optical drive a few seconds to read the Recovery Disk.
If the recovery disk is not read, and does not start automatically, go to Start, My Computer, and double-click on the optical drive icon.
(D: drive)
When the Recovery Disk starts, and comes to the question, "What do you wish to do?", click on Destructive Recovery. Also may be listed as Full Installation.
Post questions in a Comment.
Sep 27, 2010 | eMachines T5048 PC Desktop
Is there a destructive recovery option on toshiba satellite a105, i have no recovery cd
I'm not really sure what you are asking. If you see an option on startup that says something like press f11 or something for system recovery, then you can recover from the recovery partition--assuming there is one.
You can probably order a recovery CD or DVD from Toshiba, also.
Nov 12, 2009 | Toshiba Satellite A105 Notebook
It sometimes takes me over an hour of pushing the power button on and off. When I push it on, it beeps 3 times and then nothing happens. What's wrong?
there is problem with the RAM of your Computer. please check it with replacing the RAMs. hopefully it will work fine.
Please dont forget to RATE my answer
Sep 05, 2009 | Acer Aspire 9300 Notebook
Toshiba satellite display problem
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Nov 26, 2008 | Toshiba Satellite A60 Notebook
Recovery Problem
Go to Microsofts website and download the Windows XP setup discs. You will need 6 floppies to complete this task. Then change the boot order to floppy, or USB floppy and you are good to go. It will start the recovery of the system. Read through microsofts how to section for more assistance!
Jul 05, 2008 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite P205-S6287 Notebook PC Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
