Question about Cyberhome CH-DVR1500 DVD Recorder
My player won't open
I put a DVD in my player to record something and it won't do anything and said no disc, So then when I tried to open it the player it wouldn't open. I turned the unit off then back on and all it does is say formatting or reading and still won't open.
  • Anonymous Oct 13, 2008
    A friend´s Cyberhome DVD-RW have the same.The disc tray don´t open,but when disarm(get it out the cover of the dvd driver)then works.I think is a design problem.Not is Nec.When I get a solution,I would post it.Greetings from Chile.
I put a DVD in my player to record something and it won't do anything and said no disc, So then when I tried to open it the player it wouldn't open. I turned the unit off then back on, sometimes it take about three times of doing this before it opens.
Posted on Nov 17, 2008
5 Suggested Answers
SOURCE: Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Posted on Oct 28, 2007
SOURCE: Can't record
hi all, spanky new, ok here my problem!! i got the panasonicdmr-e55 for xmas, 3 or 4 years ago. since then and even wheni started to use it the disc i recorded on were -R phillips 4x. since then i have tried every available manufacture of 4x's u could think of and yet to this day it will only record on a phillips 4x disc. its been in the shop a few times for cleaning and upgrades and yet they haven't beable to tell why it only accepts PHILLIPS BRAND 4X. the new upgrade i recieved fromthe manufacture was supposed allow higher in x's on disc. it accepted 16x phillips only ONE TIME AND REJECTED 50 OF THEM, SINCE THEN ABSOLUTELY NO MORE 16X OF ANY KIND. ANYONE GOT A SOLUTION????? ps even tried 8x its still a no go. i can't afford anything since i'm on social security. message: UNREADABLE DISC. SUGGEST REPLACED DISC. OK SO THIS MORNING I TRIED TDK, MEMOREX, H.P. CIRCUIT CITY, AND 6 OTHER BRANDS ALL 4X NEGATIVE R, STILL A NO GO HELP, THANKS GINA
Posted on Feb 12, 2008
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
SOURCE: Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Posted on Aug 24, 2008
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Finalizing a DVD-R blank disc
try changeing the disk name and then see if the finalize option is availalbe.
Jun 18, 2008 | Sony RDR-GX315 DVD Recorder
Dvd won't eject
Someone is going to have to open the unit to see if something is jammed in the mechanism---a disc or something out of position.
Sometimes a gentle nudge will restore operation.
Jun 10, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvr 231 won't load
Someone needs to open the unit to see if something that does not belong got inside and to see if mechanism is functioning or not. If it does not fully load the disc it will eject it on its own.
May 28, 2012 | Pioneer DVR-231 DVD Recorder
Can't record anything on my DVD Player!
Could be a bad Laser Optic
Could be the wrong format type of DVD Disk.
AL
Mar 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Samsung DVD -VR 357 wont record or playback
Take player apart and clean the lens with a q-tip and alcohol. It is very simple and mine was doing the same thing until I cleaned the lens. DVD or CD lens cleaning does not clean it well enough.
Feb 01, 2009 | Samsung DVD-VR357
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL camerarepair@us.panasonic.com
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
Mar 30, 2008 | Panasonic Diga DMR-EH75V DVD...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
64 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
