Nokia N79 Cellular Phone Logo
Posted on Jul 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I m using n79 since 2 years, there was not single problem at all but from last 2 days my phone hangs while writing messeges and i have to restart it other functions like music, camera, gallary all are working properly only problem is that when i use numeric key, phon hangs so i cant type messeges and cant dial a number that is not in a phonbook, my keypad is working but phone hangs, i tried *#7370# and i have installed latest software version can anyone help me out ?
Anonymous
Level 2:
Sergeant:
  • Expert 189 Answers
  • Posted on Jul 01, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
189
Questions
0
Helped
21925
Points
551
Just flash it.....no other go
tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 • Lands Phones
1helpful
My bb 8220 external display simply hangs once in 2-3 days. this usually happens when there's an incoming call, and it hangs with the caller id on display........gets resolved when you pull battery out and...
There is some virus in your phone... remove the storage card and then reset all the data.... you''ll contacts and messeges, so do note the essentials... now if the virus is removed then it will not create problem for you.....
Error messege''Failed to write''
install a software called nero burning rom.. itz a gr8 software....
please vote for me...im sure this will solve your problem...
2answers
Txt messeging wth an LG neon
all you do is go onto messaging then creat message then click message then it should go to a white screen with the dotted lines and you can just slide it open write your message click send then type in their number or click contact then find the contact click on it then click send
Blue tooth connectivity, camera, writing T9
simple you just let it repaired by acellphone technician
How to trace caller ID after hanging up
If it was the Last call, Pickup the phone and dial *69 Yes the * too, it will tell you, Please note that is a Pay Per Use Feature.
Phone shutting off by itself
you may need to change the battery or have the phone reflash or you can try a hrad reset *2767*3855#
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
