SOURCE: Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
SOURCE: I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
SOURCE: Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
