Posted on Aug 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer driver for c3175 - HP Office Equipment & Supplies
Anonymous
Level 3:
  • Master 813 Answers
  • Posted on Aug 24, 2008
Anonymous
Master
Level 3:
Answers
813
Questions
6
Helped
352736
Points
2058
Gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
2helpful
3answers
I have lost the disc to my printer is there anything i can do to set it up without ?? help. thankyou
Yes, you can download the printer driver from the manufacturer's website. If you give me the printer model... I can direct you better
Could you please tell me how to release paper jammed in a hp photosmart c3175 ALL IN ONE printer scanner copier,if I pull the paper it just tears away. Thank You . RAY WINCH. EMAIL...
Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
  1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door c00652942.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  3. Replace the rear door. Gently push the door forward until it snaps into place.
  4. Press Cancel to continue the current job.
Clearing a paper jam from the front door
  1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
  3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
  4. Press Start Copy Black or Start Copy Color to continue the current job.
k24674
Grand Canyon Tech
Grand Canyon Tech
