Question about Toshiba Satellite A135-S4527 Notebook
Power supply is not charging the battery.
At first I would have to wiggle the cord inorder for the battery to charge then about a week later it stopped charging all together. So I purchased another power supply and it still will not charge. What could the problem be and what should I do next? Thanks.
  • Anonymous Aug 25, 2008
    We have the same problem.
It is a common problem. The connector has worked loose from the mainboard. If you have a friend who is handy with a soldering iron, and willing to do a bare metal teardown then you are in luck. If not, your looking at a repair that typically costs more than you should probably spend repairing your laptop.
I've remedied mine and several others in the past. When I do I ALWAYS solder wires to the mainboard and install a new connectors EXTERNALLY. This means my laptop has a rat tail, but it also will not suffer the same demise ever again.
-webdr
Posted on Sep 01, 2008
Inspiron 1525: "plugged in, not charging"
Not charging means the battery is not being charged. Batteries only have a useful life of so long, then they die and will not take a charge so you have to replace them.
If the laptop works fine when the power cord is plugged in, then just replace the battery. if the laptop does not work on the power cord, then you need to either replace the power cord or look to see if the DC Jack where the power cord plugs into the laptop is broken or wiggles. When the DC Jack it bad the battery will not charge and eventually the laptop will not turn on if the power cord can't make the connection correctly.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 22, 2012 | Dell Inspiron 1525 Notebook
I goofed. I have a Toshiba Satellite A105-S206, and I will make this as brief as I can. I have had a string of super cheap power supplies that I have been using. The most recent one stopped...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Toshiba Computers & Internet
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
You have a DC connector problem:
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
I am having charging problems, i can wiggle the cord and it will charge if I hold my thumb on it. I ordered a new cord and that didnt help at all
Ordering a new power adapter is not the solution, this is a common problem with all laptops.
The power connector that we wiggle actually shakes the power connector on the motherboard of the laptop and slowly disengages it from the motherboard hence it does not charge the battery under normal conditions. During initial stages wiggling the cable works, but later when the metal contacts go bad we are in trouble.
The actual solution to this is to replace the motherboard of the laptop or you can contact a local technician who can open your laptop and re-solder the power connector or connect a new power connector socket to your motherboard and solder it.
Dec 10, 2010 | Acer TravelMate 2300 Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Power cord cuts in and out
There are two places the trouble can be happening, at the adapter plug or at the power jack in the laptop. To determine which one is causing the power loss, hold the plug in the computer steady with your fingers while you wiggle the adapter cable. (If you have access to a voltmeter you can measure the voltage at the plug while you wiggle the cable to see if remains steady.)
If the charge light flickers it's the adapter cord that's bad. Because the wire flexes so much at the plug, it can break inside the insulation and cause the power loss. You either need to replace the adapter or repair it by cutting off the bad end and installing a new plug.
If the charge light remains on with the plug held steady but flickers when you wiggle the plug itself, the trouble is on the main board in the computer. The solder connections at the power jack have broken from the plug flexing and need to be repaired. This involves opening up the computer and getting at the solder side of the main board. It's tedious but relatively simple. If you are not experienced with soldering on small electronics, leave this to a professional shop.
Apr 23, 2009 | Acer (56.04145.901) (5604145901) Power...
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Toshiba Satellite A135 Battery Issues!!!
Here's what happened (The fix is at the end):
8 months after buying my Toshiba A135 the battery began charging only intermittently. It also would not run without the battery. I put up with it for a month then took it back to Best Buy to get it repaired under warranty. They kept it over 2 weeks then gave it back saying it was the battery, which they replaced. One week later I had the same problem again. Back to Best Buy. The guy at the counter said it was probably the battery, they had encountered a lot of that. I said no, explained it, and gave it over to be fixed. 2 weeks later I got it back. They had reset the BIOS, no hardware replacement. I got it home and it was not fixed. I took it back the next day. They kept it 2 more weeks. They replaced the motherboard. I took it home and...you guessed it the same problem on the day I got it home!!! I took it back with one week left on my warranty. I don't remember what they replaced the last time but I think it was the motherboard again. I got it home (2 weeks later) and THE SAME PROBLEM on the day I got it home. So, the lesson there is that Best Buy computer maintenance SUCKS!!
I called Toshiba to try to get them to fix it for free, and out of warranty. After several frustrating minutes of conversation with an accented person who just kept telling me that my warranty was up, I hung up and called back and got an English speaking person. SHE was very helpful, listened to my problem, agreed to give me a one-time fix ticket. They paid for the postage. When I got my computer back it was mostly fixed.
The problem was the module at the back of the computer where the power cord plugs in. It was defective. Some wire or solder had gotten loose. They replaced it and it worked fine after that, except that when it goes into sleep mode it will not wake up. I fixed that by turning off all the sleep mode options. BTW, a friend of mine with the same computer is now having the same problem.
Oct 17, 2008 | Toshiba Satellite A135-S2276 Notebook
Digital camera nv20
charging the NV20 is simple, just plugin the cable to the power supply and it will charge. Inorder to charge the camera you must leave the battery inside the camera and when it's done charging you will see the lit up arrow on the end of the cable turn from red to green.
Dec 26, 2007 | Samsung NV20 Digital Camera
Toshiba Satellite A135-S4527 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
