Question about Lexmark C762 Laser Printer
On my Lexmark C762, I get the 136 Service Fuser Error. When I change the fuser I still get the error. When warming up there is a squealing noise. Any suggestions?
  • drsuess Jul 01, 2011
    I appreciate the extensive reply and links to the different sources. Great work!
  • Lexmark Master
  • 12,061 Answers
Http://www.laserpros.com/pdf/LX-5060-C760-C762-Manual-toc.pdf
Hi, please find above the link for your service manual.
The squeaking noise is most likely dry roller bearings, a little bit of silicone spray judiciously applied to any roller parts will get rid of that usually. it may also be something jamming in the cartridge area so check that too?
Use the troubleshooting procedures to isolate that Fuser error, you may find unfortunately that it is the main Circuit board, also it maybe a sensor you will simply have to check to isolate.
http://www.fixyourownprinter.com/forums/laser/14530
Above is a helpful post about it too...
Below is your users reference manual.
Posted on Jul 01, 2011
SOURCE:
Tenemos una impresora lexmark E450DN se bloqueo y aparece error 9222 fuser service Gracias
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $70 on Ebay: http://cgi.ebay.com/LEXMARK-E450-E350-E352-40X2800-Fuser-Assembly-Warranty-/180589343591?pt=BI_Toner&hash=item2a0bf6b367
Mar 01, 2011 | Lexmark E450dn Laser Printer
Error 120.10 service fuser error Error.
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C534N, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Sep 21, 2010 | Lexmark C534N Printer
I have an error message that says 924 service Fuser Error What does that mean?
If the printer is out of warranty, your next option is to change the fuser yourself which costs around $350, so I think you would be better off getting a new printer unless you find a second hand fuser on Ebay.
Sep 03, 2010 | Lexmark T632 Laser Printer
Service Fuser Error appears on your Lexmark printer when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
Jul 07, 2010 | Lexmark C534N Printer
E 352dn Mono Laser Printer: error 922 service fuser error...
If the printer is out of warranty, your next option is to change the fuser which costs around $90 on Ebay.
May 18, 2010 | Lexmark E 352dn Mono Laser Printer
Lexmark x544 122.05 service fuser error
Service Fuser Error shows when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
Mar 23, 2010 | Lexmark T632 Laser Printer
What is error 922.14 service fuser error
If the printer is out of warranty, your next best option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Feb 23, 2010 | Lexmark T644 Laser Printer
120.07 Service Fuser Error
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
Jan 04, 2010 | Lexmark C530dn Laser Printer
920.00 SERVICE FUSER ERROR
If the printer is out of warranty, your next option is to change the fuser which costs almost as much as the printer, so I think you would be better off getting a new printer unless you find a cheaper or a second hand fuser on Ebay.
Oct 05, 2009 | Lexmark W840 Printer
Lexmark C762 Laser Printer Logo
398 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
