Question about IBM ThinkPad T40 2373 Notebook
T41p boot issue
My t41 starts normal then when windows is starting the notebook shuts down. I have to remove the batter and pwr to restart the notebook. I have run pc doctor and the only fault is that cpu is runing in the protected mode. The HDD seems to be OK, I have also tryed to boot from the CD rom with no successful results. the computer power shuts down. When running pc doctor or sys. bios the computer will run with no problem.
    Genius:
  • 2,028 Answers
This sounds like a memory problem. Remove the memory, then try each chip one at a time in each slot. Try this and let me know.
Posted on Aug 24, 2008
My netbook will not start up,it says,file is missing or corrupt
it means your notebook missing system file ( Windows file ) , so you must start repair it , and repair progress will bring and set this missing windows file
so you have to press start repair and follow the steps to fix this issue or you can fix this issue with windows CD, just boot your notebook with Windows CD , and after boot start choose repair windows.
last thing you can try this ,
    • press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start, and then press F8.
  1. On the Advanced Boot Options screen, use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
    i can help you with live help if you want this
Mar 23, 2013 | ASUS Eee 4G Notebook
Install win xp on my thinkpad t41 after installing it wont go in xp windows & blank screen appear
if you can start task manager click new task and type explorer.exe you may need to do it more than once.
Feb 26, 2011 | IBM ThinkPad T41p Notebook
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
Acer Aspire One loops on start up screen. All it does is show the acer logo, then shows the ''windows was shut down improperly'' screen with all those options and then goes to the windows xp start up...
Try tapping F8 when the acer window shows, when it shows the muliboot option, scroll down to "Last Known Good Configuration" and hit enter. If it does not boot normally, you will have to get an external dvd drive and boot off the drive with a windows installation disc to perform a repair.
Jan 07, 2010 | Acer Aspire One PC Notebook
Computer will not start after hooking up mouse
Try disconnecting the mouse and start again, I suspect a driver issue but with windows Vista that should not happen. But remove the mouse boot up, and try installing the drivers for the mouse before you connect it the the computer. This is a unusual case since Vista normal would detect the drivers automatically for you. Give me more info on this problem.
Sep 30, 2009 | Logitech V220 Cordless Optical Notebook...
Power shut down after inserting usb driver or usb mouth
This failure is caused by the usb drivers conflicts, power supply or failure on the motherboard - You can go to the IBM website and check it out more about this issue.
Sep 24, 2008 | IBM ThinkPad T41 Notebook
Startup
You'll have to check if windows is loading before it restarts. If windows starts loading before it shuts down and just loops all over again, you can easily fix this by simply re-installing your operating system. you can do this by booting from the recovery discs that came with the laptop. Now if the rebooting cycle happens before windows starts loading then this could either be a RAM or a motherboard issue and will need to be serviced.
If you don't have a copy of the recovery discs, you can always call Toshiba at 1-800-457-7777 and purchase one from them.
Sep 07, 2008 | Toshiba 2405-S221 Notebook
Windows startup is stuck for 20 minutes
Hi, If system is stuck and will not let you do anything (including power down), remove the AC adapter & the battery. Reinsert batter and apply AC power. On boot before Windows start press F8 and select Safe Mode. In Safe Mode, uninstall any program that you feel may be preventing Windows from starting normally. You can also select Last Known.... and Windows will also start with the last known good configuration. You can also use the Uninstall or the Add/remove Program. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 04, 2007 | Toshiba Portege M400 - Core Solo T1300...
IBM ThinkPad T40 2373 Notebook Logo
107 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
