Question about Canon Cameras
I have a 10D which used to belong to my editor. I have noticed that at times the camera refuses to take a picture, and flashes up an error message which is either 'Err OS' or 'Err 05' (I'm not sure which). How can I pyt this right. I think that when the error occurs the caera is trying to pop open the built-in flash, at least someone told me that today.
  • Paperboy 63 Aug 24, 2008
    I recharged the batteries on Friday evening, but on Saturday morning the problem was still the same. I have the bettery extender, and generally use the Canon 28 - 105 mm lens.
  • Paperboy 63 Aug 25, 2008
    Thank you Sweet Rascal. I tried setting to P and the flash popped up when I pressed the button. I don't have a Speed;ight (although I do have a rather unweildy Cobra which I don't like very much.
    I'll get myself a Canon Speedlight and start using that. Many thanks for your help. I didn't know what the error message was about.
    Guru:
  • 1,894 Answers
Have you cleaned your lens assembly?
if nt do that
Posted on Aug 24, 2008
  • 1 more comment
  • dewan nafees ahmed Aug 24, 2008
    its also a problem with your flash assembly.
    try using a external flash
    Err error 5 is the on board flash is obstructed ...
    Try setting the camera to 'P' and press the flash button to ensure it does in fact pop up. Are you using the camera on Auto?
    i would suggest you to use a external flash
    you wont face the problem any more
    also please rate the solution
    dont forget to accept the solution if you are Ok with it.
    Master:
  • 763 Answers
Try to refresh the device like removing the battery and try to configure it on the settings. hope that helps!
CHARCOIS
SOURCE:
Camera flashing red light and refuses to come up
the shutter assembly might be stuck or broken, just give it some hard knocking not to break but just unfreeze the shutter leaf
Dec 09, 2013 | Canon PowerShot A3000 IS Digital Camera
.HAVEN'T USED 10D FOR A LONG LONG TIME AND
Here are a few things to try:
1. Remove the main battery and the small backup battery (CR2025) from the battery compartment. Charge your main battery and put both batteries back in once your main battery has been charged. Sitting without batteries will give the camera a chance to reset itself.
2. You may have a bad CF card. Try starting your camera without a CF card or use another.
3. Try reloading the firmware (camera's operating system) using this link Canon. http://web.canon.jp/imaging/EOS10D/10D_firmware-e.html
Be careful to follow instructions exactly as restarting the camera in the middle of a firmware update will brick it and you will need to send it back to Canon for repair.
Hope that helps,
Bax
Oct 11, 2011 | Canon EOS 10D 35mm SLR Camera
I have a canon 10D that is getting an "error 99".
You could've used a non-compatible lens or the contacts are dirty. Turn the camera off then use a clean micro fiber cloth or pencil eraser to clean the contacts.
Dec 17, 2010 | Canon EOS-10D Digital Camera
Canon 10d digital camera Err 02 message - CF card error Have tried multiple CF cards in this camera with same result. Cards all work fine in my other 10d and in card readers / media players. Checked CF...
Most likey your problem is the cf card reader when ever the camera was made they could have not heated up the board all the way causing a cold solderjoint after time this joint becomes week and gets disconnected on the back side no visual damage is seen causing you the error you are getting. best thing to do is take it to a repair shop and have them fix it or the manufacture should repair it for free because there is no fisical damage.
Nov 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Problems with Flash
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Oct 16, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Incorrect Light Meter
Make sure you have correctly set the Iso/ASA factor correctly and the flash is switched off Check out the Full manual which is a PDF file on the CD
Aug 05, 2007 | Canon EOS-10D Digital Camera
Canon EOS 10D Shutter getting in the way on fast shutter speeds
Only Canon Technical Support will came to your rescue here
Jul 21, 2007 | Canon EOS-10D Digital Camera
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Cameras Logo
99 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
