Question about Microsoft Xbox 360 Console
System error 1 light code E 68
I Get the regular screen. Before the game loads or the starting screen comes on it displays the system error screen with the code E 68
  • Anonymous Mar 31, 2014
    error code 80029207
    Problem Solver:
  • 16 Answers
Error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Posted on Mar 03, 2009
How to Stop the Red Ring of Death on Xbox?
Hi Carolyn,
- notice poor game performance (if your games start taking a long time to load, or they become stutter or crash, it may be indicative of a looming hardware failure)
-notice poor system performance (if your system locks up, even when not playing games, this is a sign of hardware failing).
- understand the different light codes
Green-green lights indicate that console is powered and operating properly
1 red light-Hardware fault. Usually followed by E74 code on TV
2 red lights-overheating error. If the console becomes too hot, the system will shut down and display this light code
3 red lights-general hardware failure also known as the red ring of *****
4 red lights-AV cable isnt currently plugged in
If you do get red ring of *****:
- purchase a fix kit
-have console professionally fixed
-have console sent in to microsoft
-Prevent red ring of *****-understand what causes hardware failure
-keep your system in a well ventilated area
- avoid long gaming sessions
-keep system horizontal
-avoiding stacking items on xbox
-clean gaming area
-dust xbox
Oct 20, 2016 | Video Game Consoles & Games
Ps vita Lego Mega Pack
C1-2858-3 is a "Bad Plug-In" Error (which is a programming files the game uses to be able to display correctly on your PSV) You have to disable one of them because obviously it is not working correctly. This is how. (Reset your Vita first) then:
1.click on your game
2.now start your game, but while it is loading in the initial game loading screen hold R (Right Trigger)
3.this will bring up your recovery screen (text only).
4. go to "Plug-Ins" section, click on it, find the plug-in that is "enabled" and disable it by clicking on it.
5.now go back out all the way, and re-start your game. it should work now.
May 06, 2014 | Sony Playstation 3 (PS3) Console
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Code 68 appearing on LCD screen off a brivis LPG ducted heater
This is a error that can be fixed with a specific reset sequence. Follow this process carefully. The unit will not turn on for long and turns itself off after about a second so you need to execute step 2 immediately after step one.
Step 1 - Turn on heater
Step 2 immediately press no 1 on the keypad - this will display the error code H01 #68
Step 3 Hold down no 4 for approx 5 secs till the screen goes blank
Step 4 The screen displays all of the settings and resets
Note: you may need to do this a few times before it works - wait some time before retrying. If a reset will fix the problem this is the solution - if it is hardware a service call is required.
Jul 18, 2011 | Heating & Cooling
We have an error 68
Error 68 usually means that there is a hard drive failure.
  1. Try taking off the hard drive and starting the xbox.
  2. If the gray screen still comes up then it's a hardware failure in the xbox.
  3. You have 2 options, send it into microsoft or buy a new hard drive.
Feb 19, 2011 | Microsoft Xbox 360 Console
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Problem code E 68 red light comes on the 360 tv screen goes black.
This could be an hard drive error, try taking it off and playing a game without it, if this works try playing with it on again, or it could be an eeprom error, this is caused by not enough power getting to the console, if you have any extra fans or plug and play, remove them and have another try.
Thumbs up if this helps.
Feb 09, 2010 | Microsoft Xbox 360 Console
1 Red Light, error E 68
E68 is an hard drive error, turn it off and remove your hard drive, try to play a game without it, if it works, turn it off again, replace the hard drive and see how you get on, if it still will not work can you try the hard drive on another xbox, this will tell you if its a problem with the hard drive or an internal problem with the box.
Vote if this helps.
Jan 26, 2010 | Microsoft Xbox 360 Console
One red light - Error: E 68 - Problem code 0110
Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
We offer a repair service.
FixMyConsole
Jun 03, 2009 | Microsoft Xbox 360 Console
Stops reading the discs
try this , go to beginning screen myxbox choose system settings. click on Memory. Go to Hard drive. Then open Hard drive and begin DELETING all non essential memory robbers , such as Icons trailers stored , videos for games, ANYTHING you think shouldnt be there. I had same problem as you AND red light in lower rt. quadrant , error codes 68, 71,73,89 and etc. ALL WENT AWAY after i cleaned out my Hard Drive. Peace Out.
Apr 28, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
192 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
