Hello Garry!
To answer your inquiry, the compatibility will depend on the model that you have. Let me share with you the bands that Moto G uses, please consider if you have a CDMA or a GSM version.
Global GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
US GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
CDMA Model:
CDMA/EVDO Rev A (850, 1900 MHz)
Also, I kindly recommend you to verify with Tacfone, if your device will be compatible with their network.
If you need further information about the specifications of your device, please follow up this link:
http://bit.ly/MotoG-specs
Hope this information is helpful for you.
Best regards,
Liz
Motorola Support
Hi thanks for your advice i checked already the modem is supported on the list the
Carrier isnt
When i plug the modem in the usb no light is coming on on the router to indicate its presence however the modem green light is flashing which happens when i am using it working on my pc downloading ( franklin U600 evodo cdma rev A ) i suspect it attempting to authenticate, could you isolate in the manual for me where i can make settings changes to fix this. or what data i need from the carrier. to implement changes.
Dex.
or could it be that the carrier can block the service for shared access via any router?
Hi ok thanks alot you have been very helpful.
Dex.
Hi thanks alot i would look at the issues you outlined to me
Dex.
