The following describes the symptoms, cause and prevention of the Moire effect.
Symptoms of the Moire effect
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect.
Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect.
Preventing the Moire effect
You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
camera is turned on. Indicator light starts flashing red. memory card error comes up on screen and I...
(More)
camera is turned on. Indicator light starts flashing red. memory card error comes up on screen and I cannot take pictures. Changed memory card. This did not fix problem. I double check to see if cards in correct. Looks ok. Help!
Took my Canon PowerShot Pro 1 in to be worked on and Canon says that the part needed isn't made...
(More)
Took my Canon PowerShot Pro 1 in to be worked on and Canon says that the part needed isn't made anymore. This camera isn't that ols and the line is a popular line how is this? They say they will trade me a refurbished SX 100 IS for the estimated repair price. The problem with my camera is that you can turn it on take a picture then the lens goes in and out continually and the only way to turn the camera off is to take out the battery. I know what I paid for my Pro 1 and the refurbished replacement camera doesn't even come near that. I am very leary of Canon at this point and wonder if I make the trade will my camera then be fixed and sold as a refurbished camera. How is it that a company doesn't make replacement parts for a popular camera line they sell? I was going to use this camera as a fun little back up but I can honestly say I am so glad I decided to make all my other camera, film and digital, Nikon. Thanks for any help, insights or suggestions. Like I said not to trusting at this point and 600.00 down the tube.
