Question about Sony PlayStation Portable (PSP) Console
Power Problem my psp will not power up
  • 3 Answers
If you tried to take youre psp battery apart to try and make a pandoras battery then all you need to do to turn it on is to take battery out plug charger in turn on put battery back in pull charger out and ther you go. if thats not youre case thene im sorry
Posted on Aug 24, 2008
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Why when i switch on my psp he cannot read my memory card and he will not turn on?
Hi p_demain,
If your PSP did not turn on during step 2, it needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 15, 2011 | Sony PlayStation Portable (PSP) Console
I have a psp1000 it was fine until is started powering down all by itself. i put a brand new battery in it and shortly after it powers up, it powers down. What do i do now, and would it be very expensive...
Here are some instructions to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 05, 2011 | Sony PlayStation Portable (PSP) Console
    Need Some Help, My Psp 3001, Turns Off On It's Own, While I'm Playing A Game Or Listning To Music, What can i do???
    Here are some instruction to help fix your problem.
  • May 04, 2011 | Video Game Consoles & Games
    How to restore default settings
    Hello :
    1. Remove the battery from the left side of the PSP while it is still on. The unit will power down instantly. Wait ten seconds and then replace the battery.
    2. Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
    3. Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
    Warnings
    • If you would like to reset your PSP while it is working normally, you can do so by going to the Settings menu and selecting "System Reset." This will get rid of all your content and restore the PSP to factory settings (and subsequently remove all of your content.)
    Or try this for hard resetting :
    1. Locate your Power button on your PSP. Push the power button up for 10 seconds.
    2. The PSP will and should shut off. Leave the PSP off for 30 seconds.
    3. Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
    4. Your PSP should be working now. If not, then you may have a firmware problem.
    Warning:
    • Do not have your PSP plugged into a power supply.
    • If your PSP doesn't turn off after 10 seconds (of power button being help up) then remove your battery and wait 30 seconds, and then replace .
    PLEASE RATE !
    Jun 08, 2010 | Sony PlayStation Portable (PSP) Console
    My psp was working before but now it suddenly hanged up..i cant use it now..how can i reformat my psp?? do you know some ways???
    Hello :
    Warnings
    Warning:
    good luck .
    rate please !
    Mar 19, 2010 | Sony PlayStation Portable (PSP) Console
    I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
    Remove the battery.
    Plug the PSP charger into the PSP.
    Turn it on.
    The PSP works with no battery inside.
    If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
    Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
    My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    PSP Will not start
    What hapenned to all your PSP's is that they 'bricked'. When your PSP is installing an update and you interrupt the process, the data where the PSP's operating system (=firmware) is stored got corrupted (=broken). In very rare cases this can happen when you play a game and something goes wrong due that game. When your PSP is bricked the green lamp is on but the screen stays black.
    Now straight to the point..The solutions:
    1.If your PSP 'bricked' because you interrupted a system update (Powered off while updating, canceling update..), then you can only help it by re-installing the firmware correctly. NOTE: This is unsupported by Sony and is something you do on your own risk, for a usual PSP user it is a complicated process and i suggest you should let someone with experience do it. If you still want to attempt it, for example here's a tutorial for making a 'pandora battery' : http://www.youtube.com/watch?v=ZKFnuCfTPZo
    To find more information about this subject you could seach on google for tags like 'psp pandora mod custom firmware jigkick'
    2. If your PSP suddenly doesn't start up after or while you played a game, then you have a chance that you can recover your PSP without too much hassle. Simply let your battery run empty. After it's empty, remove the battery and let your PSP 'rest' a day without battery. After that, reinsert the battery, first fully charge it, and THEN start your PSP up (after your battery is fully recharged). If you have luck you might have your PSP working again.
    3. Contact Sony and explain the situation. Explain that you did nothing wrong. If your PSP is still under warranty they should help you..
    Good luck and if i helped you please leave feedback! Thanks
    Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
    I forgot my password on psp hoe do i reset it
    1. Take your Sony Playstation Portable (PSP) and hold the power switch for approximately 10 seconds.
    2. After approximately 10 seconds the Sony PSP will shut off. Leave off for 30 seconds.
    3. Flip your power button on your Sony PSP once, and in some cases twice. The Sony PSP will start up and should resume normal performance.
    or
    Disconnect the power cord / remove battery and hold down the power button.
    Aug 11, 2008 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    90 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
