Posted on Jul 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Canon MP380 printer has the alarm light flashing and an Error code of '6A00' in the window... What is this error
Anonymous
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Jul 01, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
13241
Points
274
Make sure that there is not a printer jam. you could also hold the power button down (5 seconds) and reset the printer.
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
2answers
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Eror p2
the web address for the manual is "http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp250#BrochuresAndManuals"
look for this document "mp250sosmwin110us.exe" install it and then look for the "troubleshooting" on the right side of the window and follow the instructions. the path is (MAIN WINDOW) >
Troubleshooting
An Error Code Is Displayed on the LED
Power Lamp Flashes Green and Alarm Lamp Flashes Orange Alternately
(go down the page until it says: Power Lamp Flashes Green and Alarm Lamp Flashes Orange Alternately )> then look for the error code. good luck!!sorry, the system is printing the same font as the book.
Have a Canon MP830. in the middle of printing, it came up with error code 6A00, and now all it does is flash the alarm light and copy light. how to fix?
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#BrochuresAndManuals
I would download the manual for windows 7 and see if the 'alarm and copy light flash' error is listed. I could not find it referred to in the support area of the canonusa.com website. Also, you could call 1-800-OK CANON and talk to a rep. about this problem.
Good luck on this repair.
3helpful
Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
6helpful
2answers
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Canon printer pixma ip6220D is showing error code 9000 alarm light flashing. What to do please?
Canon printer pixma ip6220D is showing error code 5100 and alarm light flashing. Help me how to repair it?
k24674
ADMIN Andrew
ADMIN Andrew
