Question about AEG Lavamat 72640 Front Load Washer
Aeg lavamat 76730
Hi dont have a manual having trouble washing machine stops on a approx 20 min mark with an E10 message what does this mean what do i need to do to fix it ? Cheers Melanie
5 Suggested Answers
SOURCE: AEG Lavamat 6955
Replace door seal
Posted on Jul 26, 2007
zeusfaber
  • 247 Answers
SOURCE: Problem C2 with AEG Lavamat 86741
Find the drain pump (on most front loaders, it's at the bottom of the machine at the front - often with an access hatch).
Open it up (you may want to tip the machine backwards and put a basin underneath to catch the water - and be prepared to close up again if the basin gets full before the machine is fully drained). Check that the pump impeller isn't jammed with a collection of old coins.
My next move would usually be to set the machine going in a part of the cycle where the drain pump is supposed to be running, and to give the impeller a quick flip with my fingertips (taking great care to avoid injury). If the pump doesn't run until you flick it, but then starts, this is a sure sign that you need to replace the pump motor - a quick, cheap and easy fix.
If the pump starts by itself, the the problem is more likely to be one of blocked hoses.
If the pump won't start at all, either by itself or when you flick the impeller, you need to check whether the pump is getting electricity. Do this by disconnecting the machine from the mains, connecting a voltmeter across the two terminals on the pump, then switching back on and selecting a bit of the cycle where the pump is meant to run. If you see mains voltage, then again you want to change the pump motor. If you don't, then check all the associated wiring before starting to look at the main timer. Disconnect the power before removing the voltmeter connections.
A.
Posted on Mar 05, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
SOURCE: AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Posted on Aug 03, 2008
WHAT IS ERROR E40 MEAN?
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810
E10 is related to water flow and if it isn't due to the 3-way valve being defective there's another common point to check.
The back and side cover needs to be removed to get at the condenser that, over time, can fill with fluff and stop the hot air from circulating. It and its connecting pipes can be unclipped and cleaned out.
Oct 17, 2013 | AEG Lavamat 16810 Front Load Washer/Dryer
What does E10 mean? is this an error
E10 means your machine has not filled to the correct water level (10 mins allowed) low water flow or blocked filter in the water valve . or faulty valve.check tap is turned on.
Jun 17, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
My aeg lavamat 16810 washer dryer won't dry. The error message is E10, meaning the water isn't going in. Water is running until the dryer kicks in, then the valve closes and it stops. The heater etc are...
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Oct 28, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E10 PROPLEM AEG
Your Machine manual is HERE
E10 is an inlet fault.
Check the water valve is turned on. If you are only getting a dribble of water in, then clean the inline filter at the hose inlet.
If no sound of inlet water - replace inlet valve (available as a spare from online stores)
Sep 30, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
E10 error message
I have had the same problem on an AEG. The problem it refers to is that there is not enough water entering the machine. Either the water pressure is too low or there is something blocking pipes/filters. Hope this helps
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Lavamat
have youlooked in your manual it should have some codes in trouble shooting that will help you sort out the problem. hope this helps.
Jun 01, 2007 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat 72640 Front Load Washer Logo
607 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
