Tone arm won't drop
I haven't used our JVC AL-FQ5 turntable since we moved, but I put it away in perfect working condition and it was well-packed. Now, moved in, I can't find the instruction manual.
The problem is that although the tone arm lifts and moves into the start position, it won't drop onto the record. The piece that holds the tone up off the record does not descend so that the stylus can drop.
We thought of unscrewing the piece that holds the tone arm up and dropping the stylus onto the record manually, but, since it is automatic, when it gets to the end of the record it will no doubt return to the cradle--dragging the stylus all the way across the record as it does so.
Is there something we need to adjust? Thanks!
  • Mechtild Sep 08, 2008
    Dear djproaudio, thanks so much! If we find a service center up here, we will do that. Otherwise, we're going to be looking for a new one.
    ~ Mechtild
  • Anonymous Dec 27, 2008
    I'm setting up a new Denon DP-300F turntable, and after playing the auto-return function drags the stylus across the record. I've been a DJ for several years, but I've only ever used performance tables and so I'm quite unfamiliar with automatic units. This post seems to indicate that there is a mechanism to lower the tonearm after it has been positioned over the record. Is the tonearm supposed to be in lifted position then when using automatic mode?
  • 515 Answers
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
Why does the turntable on my JVC AL-E300 stop when the arm drops on to the record. Just changed belt.
Does it restart if you manually lift the arm up?
If it does then you might have not put the belt on right. Another reason is that the problem was not the belt, but a motor showing the signs that it wasn't coping when under load. This could be caused by grease or muck inside the motor or in the drive functions. However the motor could be faulty.
May 16, 2015 | JVC Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
Arm doesn't appear to make contact with record
arm lift mechanism not dropping full extent
Apr 11, 2009 | Audio Players & Recorders
Connection to home theater problem
I do not know this model, but I am pretty sure it will not have its own preamp. Built-in preamps are a relatively recent phenomenon.
Dec 10, 2008 | JVC AL A158BK Turntable
969 people viewed this question
 Grubhead
Grubhead
