How to fix the on/off button on Dell 1908fp monitor which is stuck
  • Anonymous Mar 29, 2014
    Can I use my 1908FP monitor with a Dell Inspiron Desktop 3847 desktop?
    Sergeant:
  • 226 Answers
You might get lucky ( very lucky ) if you power off the monitor, unplug it from the wall socket, and spray some PURE DENATURED ALCOHOL into the crevices around the power button. This might work if the stuck position is caused by dirty fingers from children or a dust laden environment
DO NOT USE any water based product in this endeavor, else you will be suffering far more then a stuck button.
After application of alcohol, let the monitor dry out for at least 10 minutes ( some would say that is to long but we are trying to be safe here ), then try physically clicking the power button. With luck your fingers will notice a small difference in how the button reacts to pressure. This procedure may have to be repeated a couple to times before the button becomes fully operational again.
Now if the button is physically bad ( can no longer be responsive to pressure ), only a qualified technician should try to replace it. With most of the monitors I have dealt with it was simply to difficult to get into the monitor to make it worth my while to internally troubleshoot them.
Good luck
Posted on Aug 24, 2008
I have a dell 1908fp monitor And the silver rectangular button is stuck which stops me from adjusting the height on the monitor. How do I fix?
I didn't think this model had a height adjustment. Have you adjusted the height in the past? Maybe the silver button detaches the stand from the lcd screen.
Apr 18, 2012 | Dell Computers & Internet
Screen changes colors
Make sure the monitor cable is tightened properly at both ends first. If still no good, try a new cable between the monitor and the computer. If still no good then contact Dell for support, or just replace the monitor if it is out of warranty.
Hope this helps!
Joe
Apr 16, 2012 | Dell UltraSharp 1908FP Monitor
Dell 1908fpc screen doesnt sow anything just changes colors
Hook a spare monitor to the computer, if picture okay! the Dell monitor LCD panel is defective, cheaper to buy new. But if the symptom is the same it is the video graphics card that is defective in the computer. It would be a good idea to sub the video cord for another to rule it out.
I have a Dell 1908Fp Monitor that was given to me and it has vertical faint lines about every 2 inches. I know its not the computer cuase no other monitors do this. I am considering that its a issue witht...
I had a Dell monitor that had two faint vertical lines in the centre of the screen. Tech support told me this was 'normal' for that monitor! I sold it.
Jul 27, 2011 | Dell UltraSharp 1908FP Monitor
I've tried adjusting the height of the Dell? 1908FP but can't. I lowered it to its current height when packing and heard a click now it won'r budge even after detaching the stand from the monitor. There is...
push silver rectangular button in while pushing the monitor down and the "lock" disengages and you can then adjust the height as needed. good luck.
Jan 23, 2011 | Computers & Internet
Flat monitor will not receive image from tablet computer
i assume the monitor works on other machines. having said that,
Look on the tablet pc for a FN (function) button and look on the keyboard for blue icons. One would look like a square. pressing that SHOULD toggle 3 settings: 1 is use tablet display, 2, use monitor display, 3, use both displays. That is how it SHOULD work. You might want to look up the manual for that tablet pc to see exactly how it is done.
Oct 26, 2009 | Dell UltraSharp 1908FP Monitor
When I set the resolution to 1280x1024, the display is wider than the screen and I have to scroll to see the edges. At 1024x768, everything is fine. (Monitor is a Dell 1908FR-BK.)
IF the screen is wider then try to change the settings from the monitor buttons. We change change the screen size , move it , change brightness,etc.
Jul 09, 2009 | Dell UltraSharp 1908FP Monitor
LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Jan 15, 2009 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
