Question about Epson Stylus CX3810 All-In-One InkJet Printer
Not feeding correctly
I have an Epson Stylus CX3810 and I accidentaly broke off the plastic piece that holds the paper in place so it can properly feed into the printer. Do you know where i could buy a new piece or what its called or any other information on the problem?
    Genius:
  • 1,447 Answers
Hi-
Chances are that part may not be replaceable, but try contacting compassmicro because that is one of epson's part distributor, others vancebaldwin.
hope this helps
Posted on Aug 24, 2008
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    My epson stylus cx3810 printer prints fine from the internet or any other application but it wll not longer make a photocopy. Th paper begins as if it is starting and the printr makes noise like it is...
    This was a long time ago but I hope you havent bought a new printer
    You were right to think about uninstalling the printer, but you will have to follow the EPSON instruction to do it completely. I had a similar problem with mine.
    Go here:
    http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX3800-Series/Drivers-Support?supportLandingPage=true
    Jan 25, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Paper won't feed into printer
    I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
    Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
    Epson stylus c68 paper jam
    Hi Guest.
    Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
    Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
    Printer paper will not feed into the printer
    Your printer has a photo switch at paper feed section, this switch is triggered when there is paper and vise versa when there is none, check to see if there is/are some torn pieces of paper blocking or clogging the plastic lever from triggering the switch. A torchlight and a plastic pair of tweezers will help a lot.
    Jan 05, 2009 | Epson Stylus Photo 895 InkJet Printer
    Epson Sx200- Paper wont feed
    Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
    Dec 26, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Epson 3810
    look in and around where the paper is fed into.there maybe a small piece of paper stuck somewhere inside. if you do see something, unplug the machine and try to pull it out with a pair of needle nose pliers. if you do get the obstruction out, try feeding the paper back in and see if it now works.
    good luck.
    wg
    Feb 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
    Epson CX3810
    you could of had crash that changed it.
    Make sure the paper and layout options are set correctly
    Nov 12, 2007 | Epson Stylus CX3810 All-In-One InkJet...
    Open Questions:
    See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
    Epson Stylus CX3810 All-In-One InkJet Printer Logo
    117 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
