Question about Honeywell Heating & Cooling
Honeywell th4000 thermostat - fan won't come on. The system set to cool and the temp is set lower than room temp.
  • 182 Answers
That problem is seldom the thermostat.check all fuses and breakers....if they're ok,its prolly an internal problem to the furnace.
Posted on Aug 24, 2008
I have Honeywell Pro TH4000 series. The fan wiil not come on what do i do
Depends on what type of heat you have...gas, oil , electric, heat pump? Make sure it is the right thermostat for your heat source. Some thermostats have a switch on the back for fuel or electric.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
I have Honeywell Pro TH4000 series. The fan will not come on what do i do
It really depends on the circumstances. Are you just trying to turn the fan to the "ON" position from the "AUTO" position? If that is the case, there will be a problem with the thermostat, wiring to the thermostat, or the unit itself. That would sum up a "thermostat" problem for the fan not working. If your trying to call for HEAT/COOL and the fan isn't coming on, that is another issue.
You can try to see if the G terminal is hooked up on the thermostat, that's going to be your "FAN" terminal. If it is connected, you will have to go to the unit and see where it is connected. At this time, we would need to know the model and manufacturer of the unit. Thanks, hope it helps.
How can I set fan speed manually to balance temperature in house?
Basements are supposed to be cooler . after all they are basically a cave .
Oct 17, 2017 | Honeywell Electronic Programmable...
I have a pro th4000 series honeywell programmable thermostat and its for system type th4110d electric heat with ac how do i set the thermostat to drop a few degrees before the heat turns on right now i got...
this thermostat does not have a deadband option, the only other thing you can do is set the program for a different temp. the cycles per hour just restrict how many times the unit comes on.
Dec 15, 2009 | Coleman Heating & Cooling
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
326 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
