Question about Saeco Vienna De Luxe Espresso Machine
Dismantling a seaco royale coffee machine
I would appreciate a step by step guide to removing the top from my Saeco Royale machine so I can repair a leak with the steam pipes.
  • 515 Answers
loosen the two screw in the bean hopper, under the watertank you will have one or two screw to loosen. Take off the plastic adjustment with the beanhopper.
Take out the dregsbox and loosen the screw in the right and left corner.
Now can you lift of the top from the machine.
Posted on Aug 24, 2008
I have a seaco royal coffee machine and it keep telling me to fill water tank when its full. what can i do
Go into the menu.
Scroll with the arrows on the panel until you get to "Direct Water Connection".
Push the menu button, and chose "OFF", then push the menu button again, then esc. button twice and it should go away.
Dec 04, 2010 | Saeco Royal Professional Espresso Machine
I have a Seaco Royal Professional coffee machine and it is telling me to ventilate, what does this mean and how do I fix this problem?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out. This mean that any steam or air blocked in the water system must get out from steam wand.
Good luck
Jul 26, 2010 | Saeco Royal Professional Espresso Machine
We have a saeco royale coffee machine that is telling us to ventillate what does this mean and how can we do it
Ventilate means there is an air lock in the hydraulic circuit, to release it run the hot water cycle for a few seconds.
Jun 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Water leaking from water tank
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out it need to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won’t slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
Oct 11, 2009 | Saeco Royal Digital Plus Coffee...
Machine will not move past Warming Up start up
check with voltmetar your element on boiler for espresso,element need have continuidi,and check reset button if your machine have button on tank,and check small fuse on tank(with white rubber around)
Aug 24, 2009 | Saeco Royal Digital Plus Coffee...
I have anew royal professional the milk throther,
Aren't you supposed to foam the milk in a seperate container with the steam wand?
Jul 02, 2009 | Saeco Royal Cappuccino Espresso Machine
On our Seaco Professional the water tank is full but says empty
On the corner of the water is there a black rectangular float, if yes then the water sensor is probably not connected.
Mar 27, 2009 | Saeco Royal Professional Espresso Machine
Seaco magic delux expresso machine
They do not post a manual per se, but they have a step-by-step set up guide, starting on this page:
The actual user manual (less useful for first time) is here:
-Tha Mp3 Doctor
Mar 23, 2009 | Saeco Vienna De Luxe Espresso Machine
Dregdrawer. miss.
Make sure the machine is clean of coffee grinds. Mine has a nasty habit of dropping them behind the dregdrawer instead of in it. Remove the central unit and give it a good clean. The dregdrawer should then slide back fully into the microswitch.
If this doesn't work, you've probably got a dud microswitch.
Nov 20, 2008 | Saeco Royal Professional Espresso Machine
Luke warm coffee
check the temprature settings.
Oct 08, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
107 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
