Question about Dell 924 All-in-One InkJet Printer
PAPER JAM WONT RESET EVEN AFTER PAPPER WAS REMOVED ON A DELL 924
On the paper jam ,I tried to pull the ink cartridge over to center. It came over a little & then it jammed up.I noticed the ink cartridge lock tab had popped up & jammed it to the right , once I got the tab back in place the code cleared & it works good now.
Posted on Aug 28, 2008
Non-existent paper jam
There is almost certainly an optical sensor somewhere that either has a tiny bit of paper or dust in it. Try blowing dust out of the insides of the printer with a shop vac set to blow air out. Also try disconnecting/reconnecting the optical sensors throughout the paper path of the printer. Only do these things with the printer disconnected from everything.
Nov 01, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam
Had the same problem with my Dell AIO 942. Found the solution at http://en.community.dell.com/forums/t/18044557.aspx?PageIndex=2
Jun 15, 2009 | Dell 924 All-in-One InkJet Printer
Unable to print.
Most of the new printers have little springs that pop out and then it won't print. If you have tried to remove the paper from the front you might have damaged one of them or the little pins that go with them. If you have a warranty I would use it now.
May 17, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam in printer
go here for the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf") good luck!
Feb 24, 2009 | Dell 924 All-in-One InkJet Printer
PRINTER JAM
look for small, small pice off papper in the printer where pappers pass tru
Sep 29, 2008 | Dell 1720dn Laser Printer
Papaerjam lite stays on, no paper jam
It is possible that there may still be a small piece of paper blocking or lodged in the exit sensor area. It is also possible that when removing the jammed paper that the sensor arm became dislodged and thus creating a false jam code.
Jun 25, 2008 | Sharp AL-1641CS All-In-One Laser Printer
924 printer paper jam
below the opening part to take a copy you open it, the cartridges will move to a side automatically. There you will be able to see the paper.
May 03, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Reading "paper Jam" but no jam-no paper to be found?
dell all-in-one 924 keeps giving message to clear paper jam. There is no paper in the printer HELP!!!!!
Oct 23, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
166 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
