Question about Sony Playstation 3 (PS3) Console
Hard disk file system is corrupted
Games states hard disk file system is corrupted, system attemps to restore but goes back to the same message, please help
  • Anonymous Dec 04, 2008
    i unplugged my ps3 and i tried to plug it in and start it up and it says the system hard disk is corrupted and it wont let system restore
  • Anonymous Feb 20, 2009
    i have the same problem - keep getting the message "The hard disk's file system is corrupted and will be restored" when i select for restoring to begin it restores itself and comes back with the same message.
    Somebody said to turn it on and off at the mains about 6 times leaving braks in between and that should work but i keep getting the same message!
    my warranty has ended and i dont want to pay a fortune to get it fixed.
    i will try unplugging it for 24 hours
You might want to invest in an external USB hard drive for the PS3. They sell for around $100.00, I've seen them at Best Buy. Try this, unplug all the cords from the PS3 for 24 hours. This same thing happened to me recently, because my 6 year old son thought he could just turn it off using the switch in back instead of logging off, and shutting down the unit the correct way. After I hooked the unit back up the message disappeared, however backing up your hard drive is the ideal thing to do. I hope this advice helps.
Posted on Aug 25, 2008
Everybody keep your reciete.
Posted on Aug 24, 2008
Hard disk file system corrupt
Bad sector or MBR on Hard drive needs replacing
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Tip
The hard disk's file system is corrupted and will be restored. PS3
Hi, should sort your problem:
"The hard disk's file system is corrupted and will be restored"??
Here's what to do - as instructed by Sony UK (Tel: 0844 736 0595):
If you've tried `restoring` and it continues to reset/repeat to the same message:
Turn the console off by holding/pressing the power button down until you hear three spaced out beeps (before powering down);
Then hold in the power button again until you eventually hear a first and second beep - followed by a quick double beep, then take your finger off the button;
This should bring up a six option menu, such as `System Restore` etc;
Select `System Restore` and follow the instructions;
If in the event it repeats your first problem, i.e. repeating the same message, then repeat the above process to get back to the six options, although this time select `System Reset` or similar;
This will sort your problem although you will probably lose saved game data (if not backed up on a memory stick or something prior to your problem).
If you play Modern Warfare 2 online, then your data will be saved on the Sony Server anyhow and won't be lost.
When carrying out the above actions, the loading bar can be a bit slow at times. This is due to repairing the corrupted data etc on your hard-drive.
This worked 100% for me and I've no doubts will also help you.
Any problems please ensure you contact Sony on the number above.
Good Luck!!
on Jul 03, 2010 | Video Game Consoles & Games
"The Hard Disk's file system is corrupted and will be restored"
rpoulley
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Mar 07, 2010 | Sony PlayStation® 3 (80GB) Console
Error message that says the hard disk's file system is corrupted
tlatrice_66
Issken
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
This is happening because your console is not recognizing the HDD (hard drive) for what ever reason. The corrupted files are about to do damage to your console, and a PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the HDD reset menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair. You can "back-up" your saved data using a "USB storage device" Like a memory stick or even your iPod.
If none of this works, or the console just won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck, Indra!
May 30, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
PS3 issue.
roushfenway
If you are getting the corrupted drive message and the built in PS3 options are fixing the drive then you will have to pull the drive and format it externally with a computer. The link below will help you do this.
Issken
Oct 13, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 hard disk files corrupted???
by a new hard disk it is easy. The only thing is that you will LOSE  EVEYTHING THAT YOU HAVE ON THERE! you can find a cheap one for like 80 bucks I have a 160 gig in now and i paid 89.50 email me if you have questions baldwinkk@gmail.com
May 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
