Question about JVC 50W x 4 MOSFET Apple iPod /Satellite Radio/HD Radio-Ready CD Deck
I LOST MY REMOTE CONTROL FOR MY JVC DVD/CD CAR PLAYER KD-DV4306
I WANT TO GET HELP HOW TO SELECT THE NTSC OR PAL WITHOUT MY REMOTE CONTROL. TNX
    President:
  • 196 Answers
If you reset the radio automatically go to ntsc. reset pressing a little hole reset botton whith a pen tip.
Posted on Apr 28, 2010
Pioneer DVD player the screen will not stay still
maybe the dvd is st to pal/secam, and your tv is set to ntsc...look for the pal/seca/ntsc button in your remote control of dvd player and set the player to ntsc...tv recievers are set to ntsc by default if you are in asia...
Oct 15, 2014 | Car Audio & Video
How to convert the my jvc dvd player to ntsc to pal or vise versa, coz i used old tv so i need to change it . tnx my jvc model is xv-tha30 dvd cinema system
You have to use an external device to convert NTSC to PAL or vis versa. The device cost between 175 to 250 $. I think you can buy a small new generation multi system TV for that price !!!!.
If you still want to buy click on the below link.
http://www.converters.tv/signals/ntsc_to_pal.html
Mar 18, 2011 | JVC TH-A30 System
I have attached a DVD Player to my LG TV, using the appropriate cables. I have sound and a black & White picture. What have I done wrong please?
It is very simple, the mode of your DVD or TV is not correct. Check the NTSC/PAL setting's on your remote control for the DVD player. If your DVD player is on PAL system, then you TV should also be on PAL system. Likewise for the NTSC system, possible to put both on AUTO mode then do it. Don't get confused it is just a simple setting which you can do it without any problem, and in future you can do it for others.
Mar 04, 2011 | LG Televison & Video
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
Jun 16, 2010 | JVC TH-A9 System
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Audio Players & Recorders
Problem with tv system
You need to change PSM (preferred setting mode) for video format (PSM menu 9)
Check page 23 on how to change PSM and page 24 for list of PSM, of the user manual here : Download INSTRUCTIONS
Do not forget to vote the solution.
Aug 24, 2008 | Car Audio & Video
Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Jul 29, 2008 | Oritron NPD3117 DVD Player
NTSC/PAL
Surprisingly, and I've never understood why this is, the remote has a lot of functions on it that the buttons on the dvd player doesn't have. I think it is more likely that it ISN'T possible to do.
Look on the front of your DVD player. If it has a "menu" button and a four-way directional pad, you may be able to stop whatever dvd is playing, go into the dvd player's menu and change the settings that way. If not, then you can't.
Feb 03, 2008 | Televison & Video
Jvc xv-s302 only plays black and white
Look at the back of the DVD player it should have a NTSC & PAL switch ,but remember to switch off the dvd player after you change it over to NTSC or PAL
i hope this will help you
craig:)
Jul 01, 2007 | JVC XV-S302 DVD Player
Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Mar 17, 2007 | JVC KD-G420 CD Player
JVC 50W x 4 MOSFET Apple iPod /Satellite Radio/HD Radio-Ready CD Deck Logo
154 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
