Question about Polaroid TLA-01911C TV
Resolution issues i cant get the tv while in computer VGA to go higher than res 1024x768@70hz it just says resolution not supported and in the the book it says it supports up to 1400x900
    Problem Solver:
  • 7 Answers
Are you using a PAL video on an NTSC Polaroid Television?
Posted on Jul 18, 2010
  • james berkhimer Feb 27, 2011
    sorry of the late reply my computer broke and then lost track of this site
    it really dosen't matter when connected as a computer monitor. but if i am wrong NTSC is what the USA uses for brodcast TV as well as input devices but since it connected to a computer using the VGA port, NTSC or PAL dose not apply.
Why wont the tv screen work for an additional monitor for my computer
TV screen resolutions are usually much less than computer. If you can scale down your PC screen res AND you can connect from your PC's VGA to TV VGA you might stand a chance.
Feb 06, 2015 | Televison & Video
Hi, I am trying to connect my laptop to my TV using VGA (MALE) to VGA (MALE) cable. I am able to see black lines on the TV with noise.How can i correct this ?
You didn't say, is the TV HDTV??
From Windows help menu, press F1, type in "VGA connection" I found this:
Why can't I hear audio when I connect my computer to an HDTV?
VGA, DVI, and component video cables do not support audio signals. HDMI cables do support audio signals, but not all HDMI-enabled video cards support audio. If your HDTV has an audio input, you might be able to connect a separate audio cable from your computer's sound card directly to the TV. Otherwise, you'll need to connect the audio signal to a different output device, such as external computer speakers or your home stereo system. For more information about sound cards, see Sound cards: frequently asked questions.
From Wikipedia.org search VGA connection:
1.
Video Graphics Array (VGA) refers specifically to the display hardware first introduced with the IBM PS/2 line of computers in 1987,[1] but through its widespread adoption has also come to mean either an analog computer display standard, the 15-pin D-subminiature VGA connector or the 640×480 resolution itself. While this resolution was superseded in the personal computer market in the 1990s, it is becoming a popular resolution on mobile devices.[2]
VGA was the last graphical standard introduced by IBM that the majority of PC clone manufacturers conformed to, making it today (as of 2010[update]) the lowest common denominator that all PC graphics hardware can be expected to implement without device-specific driver software.[citation needed] For example, the Microsoft Windows splash screen appears while the machine is still operating in VGA mode, which is the reason that this screen always appears in reduced resolution and color depth.
VGA was officially superseded by IBM's Extended Graphics Array (XGA) standard, but in reality it was superseded by numerous slightly different extensions to VGA made by clone manufacturers that came to be known collectively as Super VGA.
2.
The same VGA cable can be used with a variety of supported VGA resolutions, ranging from 640x400px @70 Hz (24 MHz of signal bandwidth) to 1280x1024px @85 Hz (160 MHz) and up to 2048x1536px @85 Hz (388 MHz). There are no standards defining the quality required for each resolution, but higher-quality cables typically contain coaxial wiring and insulation which make them thicker. A quality cable should not suffer from signal crosstalk which occurs when the signals in one wire induce unwanted currents in adjacent wires, ghosting which occurs when impedance mismatches cause signals to be reflected (note that ghosting with long cables may not be the fault of the cable but may instead be caused by equipment with incorrect termination or by use of passive splitters), and other signal degradation effects; shorter VGA cables are less likely to introduce significant degradation. Some higher-end monitors and video cards featured 5 separate BNC connectors for RGBHV signal, allowing highest quality connection using five 75 Ohm coaxial cables.
I hope this helps, I find the sales reps at Best Buy very helpful.
Dec 04, 2010 | Computers & Internet
I plugged in the VGA cord from my computer to my television
Most likely your current resolution isn't supported by the TV. Before you plug your TV up to your computer, set your desktop resolution to 1024 x 768. This is the standard and is supported by most if not all flat screens. If it doesn't work on this setting try 800 x 600 or 1280 x 768. One of those three should show up. If no resolutions work, then there is something wrong with the TV. If other monitors work on your computer then the computer is just fine.
Nov 06, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Some games need 1440x900 resolution to play but when i go to the display settings to change it, its not there just 1360x768, 1600x1200 and lower ones. I need help????
Hi there. If you're able to get 1600x1200 on the monitor, that should suffice--anything equaling or larger than the game's required res is ok...the picture will have a little bit of border on the edges because of the higher resolution but shouldn't be a hinderance at all. Remember this...the higher the resolution, the harder the graphics card has to work to maintain proper movement of the images in the game. Use the exact res if possible. However a close, higher res is fine, too.---Rick
Oct 03, 2009 | HP Compaq WF1907 Monitor
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will support resolutions up to 2048 x 1536, which should be ok.
Apr 23, 2009 | XFX GeForce FX 5500 Graphic Card
Dynex 19 LCD
Yes, the current video driver is not configured for the higher resolutions supported by the Dynex TV/monitor. I ran into this same problem setting up my system. The solution is simple and only requires that you uninstall your current video driver and reinstall with the latest version driver for your systems VGA. You should be able to run the monitor at a resolution of 1440 x 900 with Color Quality at 32 bit Highest. Hope this helps.
Jan 11, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
My computer monitor loses resolution
try running your graphics card in separate screen mode im thinking you may have it in clone mode and is running both displays at the same res, or if the projector can handle it try running the projector at higher res
Dec 15, 2008 | InFocus LP70+ Multimedia Projector
I reloaded win xp get lowest res. cant get higher res
sounds like you need a driver for you video card go to driver.com
Dec 14, 2008 | HP W1707 LCD Monitor
"Not Supported Mode" Message...
Your tv does NOT support any higher than 720p res.
Is your cable box set to this? If not, and it is set to 1080i than it would explain this, and is also a common problem with computer(vga) connections even with monitors. To see the current resolution the box is set to hook up a yellow jack to the to from cable box just to get the picture back long enough to navigate to a setup menu and lower the resolution back to the highest supported which is 720p
Nov 04, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Polaroid TLA-01911C TV Logo
145 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
