Question about Kenmore 15343
Kenmore 15343 incorrect stitching
My machine is showing the bobbin thread on the top side of my fabric. I have tried changing my needle, adjusting the tension as stated in the manual, cleaning all the lint out of the bobbin case, from around the feed dogs etc. I also checked to see that my bobbin was inserted properly. With adjusting the tension I was able to get a little bit better stitch but it still doesn't look correct. My machine is about 2 months old and I am new at sewing so I'm a little bit of an idiot about sewing machines. Any suggestions?
  • Anonymous Feb 03, 2009
    the stitch does not come out well and its worse down side...i am new too...
Try adjusting the tension everytime you use the machine.
adjust upper and lower thread tensions.there are bobbin adjustments for thread. also use cotton thread ,many older sewing machines prefer cotton thread,try using guterman's thread.also make sure nthe needle size is correct and that the needle is inserted in the machine correctly.
Posted on Aug 15, 2010
    Problem Solver:
  • 6 Answers
When you see the bobbin thread on top of the fabric this can be on e of 2 things usually. 1) thath the top thread tension is too tight or that the bobbin thread loose. Remember the saying righty tighty, lefty loosey. If you have adjust the top tension and it has helped just not enough perhaps you need to try the bottom a small screwdriver to turn the little screw on the outside of the bobbincase may do the trick. only small adjustments 1/4 turn at the most at a time to the right to start with.
Posted on Jun 24, 2009
My Bernina 200 bobbin thread snagged and now the bobbin thread will not catch the top thread when I sew, thus, there are no stitches made in the fabric.
1. CHANGE NEEDLE.
2. ADJUST BOBBIN TENSION. MAKE SURE YOU ARE USING THE RIGHT BOBBIN FOR THE MACHINE. THE WRONG ONE WILL NOT ROTATE FREELY. HANG FROM FINGER AND BOB. SHOULD EXTEND ONE INCH WHEN ADJUSTED RIGHT.
3. ADJUST TOP TENSION. (START AT 3)4. EXTEND TWO INCHES OF THREAD FROM BOBBIN. HOLD TOP THREAD TO THE FRONT AND A LITTLE TO THE RIGHT.
5. TURN HAND WHEEL TOWARDS YOU. THE BOTTOM THREAD SHOULD COME UP FROM UNDER THE PLATE.
6. IF THE THREAD DOESN'T FEED FROM THE BOBBIN TO THE TOP OF THE PLATE THE TIMING IS OFF AND WILL NEED TO BE ADJUSTED.
Jan 02, 2015 | Bernina Sewing Machines
My stitch length is tiny and will not change
When selecting a stich, there's a button with a triangle with one edge pointing down. There you can select Needle Position and Stitch Length. --PDF manual, page 23
The thread tension has no influence on the stitch length. It just adjusts, where needle thread and bobbin thread 'meet' inside the fabric. A too high tension means, the bobbin thread is pulled trough the fabric and can be seen on the upper (needle) side. A too low tension means, the bobbin thread is not pulled through the fabric and you can see the needle thread on the bobbin side.
Jul 08, 2014 | Janome Memory Craft 9000 Computerized...
My kenmore sewing machine model 385.18221 is not really sewing. It seems like it is for a couple of stitches then the fabric goes down into the machine, threads r hung up in the bottom and when u get the...
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Stitches are skipping, bobbin problem?
Here are a few things to try. One of these should fix your problem.
* Re-thread your needle
* Change your needle
Your needle may be blunt, bent, or otherwise damaged.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
* Change your thread
* Adjust your thread tension
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure. I know you said you checked this already but it might not hurt to double check it.
Important Note:
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
stitches.
Hope this helps.
Sep 15, 2009 | Kenmore Sewing Machines
Whenever I zig zag my machine skips stitches.
Try these solutions.
*Change your needle
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
stitches.
I hope this helps you.
Sep 15, 2009 | Bernina Activa 130
Sometimes my machine will skip a stitch
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Sep 12, 2009 | Singer Sewing Machines
QE 440 BSR sewing along fine then skips 2-3 stitches, bobbin seems to not catch the stitch.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens or a universal needle for either. Make sure your needle is appropriate for the type of thread you’re using.
Important Note:
I hope this helps.
Sep 09, 2009 | Bernina Sewing Machines
Kenmore sewing machine 15343
I had this problem but have resolved it (for the most part) by lowering the needle down into the fabric before beginning to sew.
Aug 12, 2008 | Kenmore 15343
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Sewing Machines Logo
132 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
