Question about Umax Astra 3400 Flatbed Scanner
Power supply I have a umax 3400 scanner. I have misplaced the the power adapter. I need a desription of the power adapter because I don't want to plug the wrong one into the unit.
  • hypnoclinic1 Sep 30, 2008
The Umax 3400 scanner uses an adapter with 12 volt 750mA output.
You can see it / buy it ( $11.95) on the UMAX website.
Just Google: umax scanner power adapter
Posted on Nov 13, 2008
I have the same problem
Posted on Sep 14, 2008
Asking for adapter cable for scanner umax astra 3400
Should be a standard USB device cable. Any half decent home electronics store sells them. The same cable is used to connect most USB printers.
Mar 15, 2014 | Umax Astra 3400 Flatbed Scanner
Im looking to remove my turbo charger from my astra 1.3 club, please advise
i already service that kind of scanner and the power adapter is 12 v output with only round head male plug. you can change that at least with same specs.
Apr 09, 2010 | Umax Astra 3400 Flatbed Scanner
What does umax astra 3400 scanner power adapter looks like/
who cares if it is the proper voltage,amps and plug. . you need a wall wart , the plastic box with two flat blades sticking out that 12volts DC center positive ,700 milliampsfor the non negatine scanner and 1 amp(1000 milliamps) for thr negative scanneer model an AC/DC adapter look around at 2nd hand stores they usually have a selestion or order online from electronics supplier
Jan 13, 2009 | Umax Astra 3400 Flatbed Scanner
I need umax astra 3400 scanner software
Have found information on umax.com !
Solution is VistaScan X CD only for Windows XP, when you use it withaout Internet-Connection (local)
http://www.umax.com/vistascan-x-cd/
Or: VueScan also for Windows 10
https://www.hamrick.com/de/vuescan/umax-astra-3400-treiber.html
But you've some costs...
Nov 14, 2008 | Umax Astra 3400 Flatbed Scanner
Scanner test keeps failing
hi
the scanner wont work, the green power lights on all the time wont go off .
we have re-installed the disc after uninstalling it but still no joy ,can you help please . thank you so much
mr derek watson.
Aug 03, 2008 | Umax Astra 3400 Flatbed Scanner
Umax Astra 2000P Power Supply
You can use any over the counter 12 volt power supply from a DIY or computer shop, just make sure the tip of the
plug is switched to + and the ring is negitive
also that the power supply is rated at about 18
watts or higher
Jul 31, 2008 | Umax Astra 2000P Flatbed Scanner
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
Umax Astra 3400 Flatbed Scanner Logo
622 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
