Question about NexxTech NWOMMI Mouse
Connect button where is the connect button?
At the back of the system
Posted on Aug 27, 2008
Can't connect to localnetwork
Select your network , enter your password --- then ok to connect - upon it failing to connect to local network -- do the following - press home button 5 times, fwd button 3 times , revs button 2 times - takes u to a sub menu - select update software --- after completed - follow steps on screen & connection should work -- if not then press home button 5 times , fwd button, play button, revs button , play button, fwd button -- sub menu opens select disable ping - then do setup - and connection should occur
Mar 03, 2013 | D-Link DI-714P+ Enhanced 2.4GHz (802.11b)...
After re-installing Windows XP, I cannot connect to internet
There is a Wizard in XP for this, which may assist.
- left click the Start button, right click on Internet Explorer
- left click the Connections Tab, then the Setup button
- left click the Next button, then choose "Connect to the Internet", then Next
- Choose the option to "Set up my connection manually, " then left click the "Next" button.
- Choose the option to "Connect using a broadband connection that is always on, " or other choice if more appropriate, then left click the "Next" button
- Click Finish
Mar 11, 2012 | Compaq Computers & Internet
How to connect wireless controller to my console
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  3. Press and release the connect button on the console.
    360s_bindbtnhand.jpg consoleconnectbtn.jpg Xbox 360 S console Original Xbox 360 console
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button.
If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Jul 15, 2011 | Video Game Consoles & Games
How do i can et internet on my laptop xp to connect from wireless router it show a lock how can i unlock
Step 2: With the left mouse button, click on 'Control Panel'.
Step 3: With the left mouse button, click on 'Network and Internet Connections' (Network Connections, if in Classic View).
Step 4: With the left mouse button, click on 'Network Connections'.
Step 5: With the right mouse button, click on the 'Wireless Network Connection'.
Step 6: With the left mouse button, click on 'Properties' button.
Step 7: With the left mouse button, click on the 'Wireless Networks' tab.
Step 8: With the left mouse button, click on the name of the wireless network, under 'Preferred networks', that you want to automatically connect to.
Step 9: With the left mouse button, click on the 'Properties' button.
Step 10: With the left mouse button, click on the 'Connection' tab.
Step 11: Ensure there is a checkmark in the checkbox, next to'Connect when this network is in range'.
Step 12: With the left mouse button, click on the 'OK' button.
Step 13: With the left mouse button, click on the 'Advanced' button.
Step 14: With the left mouse button, click to select 'Access point (infrastructure) networks only ' (This will help prevent your connection from bouncing around from one network to another).
Step 15: With the left mouse button, click on the 'Close' button.
Step 16: With the left mouse button, click on the 'OK' button.
Jun 13, 2010 | Computers & Internet
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
Mar 22, 2010 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
I have a logitech wireless mouse, i don't have the manuel or anything that came with it and i'm trying to connect it to my home desktop computer.. the piece that connects to the computer works the lights...
Click on the connect button on the remote (part connected to the PC) and click on the connect button on the mouse. Move the mouse around after you press that button. It should connect.
Also make sure your batteries are fresh.
Once working, I've found that Microsoft's Intelli mouse driver does a better job then Logitech drivers.
Jul 25, 2008 | Computers & Internet
Mouse and keyboard not working
  1. Remove the batteries from the keyboard.
  2. Make sure you have the mouse synchronized. To do this, press the connect button on the receiver, then press the connect button on the mouse.
  3. Open the iTouch Configuration Panel by double clicking the iTouch icon in the Systray.
  4. Click the Cordless tab.
  5. Click the Connect button in the Control Panel. A dialog box will appear instructing you to press the connect button. Before you do, you should re-insert the batteries.
  6. After inserting the batteries, press the connect button on the keyboard.
  7. Verify both devices function correctly.
If this does not work, please try the steps below:
  1. Remove the batteries from the keyboard and press keys on the keyboard repeatedly (as if typing) for approximately one minute. This will clear out the capacitors.
  2. Press the Connect button on the receiver.
  3. Press the Connect button on the mouse. NOTE: You may need a pencil tip or other small tip to press the connect button.
  4. Press the Connect button on the receiver.
  5. Insert the batteries back into the keyboard.
  6. Press the Connect button on the keyboard.
Jan 09, 2008 | Logitech Cordless Desktop EX110
Unable to connect
hi
Press connect button on receiver and then press connect button under the mouse.
WAIT 20 seconds.
Press the connect button on the receiver and then press the connect button under the key board
And there you go. Happy surfing
Paul
Oct 30, 2007 | Logitech Cordless Desktop EX110
NexxTech NWOMMI Mouse Logo
29 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
