Question about Hoover Washing Machines
I've got a hoover premier 705 4.0kg washer.It will wash and drain,but it won't spin dry..I've checked the pump and hoses (not blocked).And you can't take the back OFF this one,you have to lay it down and try to fix it from the bottom.which is a pain in the !!!!!.Hope you can help,it hard being on a pension when things go wrong....David.
Hey, have you looked at the belt going from the motor to the drum? I am currently trying to make ours start spinning again too, and the problem is that the belt keeps dropping off, I am just trying to find out the size of the belt so I can go buy a new one. If this is your problem, it should be reasonably cheap to fix, just look up an (electrical) appliance spares shop in the yellow pages. I think the size I am looking for is a Z550 or Z600.
Posted on Sep 12, 2008
Premier 300 Not spinning
Check if the drain hose is blocked. Check the wires aren't loose on the drain pump. If all that's ok you will need to replace the drain pump.
Jul 08, 2013 | Miele Novotronic Premier 500 Front Load...
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Jan 05, 2012 | Hoover Washing Machines
Lg wm2455h is not draining: i have taken out and cleaned pump filter and that did not correct the problem. I place the machine on the drain and spin cycle and i can hear the pump hum, but doesnt drain. ...
most likely you have a bad pump and it needs to be changed out or something is still stuck in the impellar,stick your finger into the pump and feel around the impellar,i've found under bra metal pieces stuck in there,elastics and string rapped around it and coins lodged in between the impellar and wall of the pump,if the pump is bad or something is stopping the impellar from spinning it will hum,power is going to the pump but the motor isn't spinning.
Nov 12, 2011 | Washing Machines
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
Washing machine not spinning draining
you will either have a block in the pump or in the grey hose that connect onto ur main drain. Firstly check the grey pipe by taking it off and using a bucket put the hose into it and then attempt to get the machine to drain. Also look in the spiggot connected to the main supply as items or sludge can block this part aswell. If not drainin then the likely cause is in ur pump chamber most washers have a point of entry on the front at the base of the applaince. normally u just turn the cap and the water and block will come out.
Hope this helps
Mar 20, 2010 | Hoover Washing Machines
Not spinning the water out
yoou need to check the drain pump for an obstruction.you can use a wet dry shop vac attach it to the end of the drain hose to remove all the water.once the water is removed.take off the hoses from the drain pump and check to see if there is something stuck in it or blocking the pump if none of these things are present you may have to replace the drain pump.good luck with your washer.let me know how this works for you.
Jan 22, 2010 | Hoover SE230 Front Load Washer
NOT SPINNING OUT DRY ENOUGH
There is a partial blockage in the drain line. You need to remove the pump and check for obstruction at the impellers. If clear, check the pipes from the drain motor back to the drum and to the pipe outlet for partial blocking.
Oct 23, 2009 | Hoover HTC243 Top Load Washer
M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 22, 2009 | Hoover AAA140 Front Load Washer
Washing Machines Logo
144 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
