Question about Olympus Camedia D-390 Digital Camera
Video output
What is the video output used for?
    Master:
  • 852 Answers
The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR.
Posted on Aug 31, 2005
How to convert a videos
Launch your video converter program if you have one.
If you do not have a video converter program, consider free programs such as AVC Video Converter http://download.cnet.com/any-video-converter/3000-2194_4-10661456.html
or
Prism Video Converter
http://dw.com.com/redir?edId=3&siteId=4&oId=1770-20_4-0&ontId=2194_4&lop=linktitle&ltype=dl_elite_gen&pid=12172333&mfgId=10012381&merId=10012381&ttag=lst-1&destUrl=http%3A%2F%2Fdownload.cnet.com%2FPrism-Video-File-Converter-Plus%2F3000-2194_4-1064
These programs are cross-platform applications, compatible with both Windows and Mac OS X operating systems.
Click "Add Files" or "Add Video," depending on the program that you are using.
Locate the video file you want to convert from the folder you saved it in, then click "Open" to import it to the video converter program.
Play your video on the monitor to ensure that it is the video that you want to convert.
Select the video format you want to convert your video to in the "Output format" or "Profile" window.
Choose from a number of video formats, such as MP4, AVI, MOV or WMV. Different models of MP3 players use different video formats, so refer to your MP3 player's documentation for the compatible format.
Select the output video size you want to use. Video sizes vary with different MP3 players. Some MP3 players support 320x240, while others support 640x480.
Refer to your MP3 player's documentation for the supported video size.
Select the audio codec that you want to use for your output video file.
Some of the most common audio formats include MP3, WMA, AAC and WAV.
Audio codecs compress audio with different output quality settings, so refer to your MP3 player's documentation for the supported audio codec.
Select 2 or "Stereo" in the channels box for a balanced left and right audio output.
Click "Browse" and select the folder where you want to save the output video.
Select a folder or location that you will be able to remember and access quickly.
Click "Convert/Encode" to begin the video conversion process.
A status bar displays the progress of the conversion.
When the process is finished, your video is in the format that you selected
hope this helps
Sep 27, 2012 | Audio Players & Recorders
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
When powering up all i get is a red screen with black lines across. Sound is still there and can change channels and ocationaly after several attempts it will give a picture albeit rather green.
Hello
Your TVs video output transistor [Red] has got shorted. Usually a transistors are used in most of the colour telivisions in video output stage.. If it is a transistorised video output stage, replacing red output transistor will solve the problem. In some modern sets there are so many types of Integrated Circuts [ICs] are used. If your TV uses Ic as video output, replace the Ic.
Oct 16, 2010 | Loewe Aconda ACO9303 30" TV
Is a yamaha rx-v465 supposed to recieved both
What connection do you use?
This receiver supports both video and audio over HDMI. It has also other video inputs, but it doesn't have any video processing.
So if you connect your equipment for example to component video in, its video output will be present only on component video out (NOT on the HDMI output nor s-video output).
Jan 03, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My husband is looking for a user manual for a Terk s-video switch. He got the used item from someone at our church - but they had no documentation for it. Where can I get a user manual?
From my search results, the model number is Terk VS-4. You can view the user manual by clicking here. You need Adobe reader to view it.
More information is given below:
This unit allows you to feed up to 4 stereo audio and video sources to one unit (normally one television which has A/V inputs).
It also allows you to connect a second device such as a portable recorder or amplified loudspeakers to the front AUDIO only output (stereo minijack).
The two outputs are always live.
There are four switches on the top of the unit which allow you to select which of the four inputs you want to use.
Since this is a passive device (no AC or batteries) the input which you select is indicated by a red mark (non-illuminated) which appears when you select the input.
This unit is a perfect solution if you have a receiver or amplifier with no video switching or without enough video switching (or with no S-video capability).
...Placing the unit directly on top of a TV could cause electromagnetic interference. If this occurs simply move the cables and/or the switch box .
S-video signals will only be output when a corresponding S-video signal is connected to the input. For example, if you connect a standard VHS VCR to input 1 using composite video, only composite video (not S-video) will be output from Output #1.
Only output #1 should be used for dubbing or editing, since recording levels will drop if you use both Output #1 and Output #2 simultaneously."
Source
Dec 16, 2009 | Televison & Video
How to change the video output on denon avr 486-I have 3 devices using the component video inputs (playstation 2, xbox 360 and a dvd player) but i have an analog video output going to my tv. my devices are...
under the system setup menu go to video setup, and re assign the devices, then make sure the video output is assiggned to component as well. That should give you what you need
Jul 16, 2009 | Denon AVR-687
NAD T753 s-video in, component video out problem
I have the same amp. You have to have the same input as you do output for video...ie: s-video in/s-video out, composite video in/composite video out. I know it sucks but thats how NAD designed it.
Dec 01, 2008 | NAD T753 Receiver
Video Connections
These are all the connectors on the back. The "1 x component video output" indicates that you can use the "3 color video cord" you have, better known as Component Video Cable.
Connector Type: 1 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x component video output ( RCA phono x 3 ) - rear ¦ 1 x S-Video output ( 4 pin mini-DIN ) - rear ¦ 1 x composite video output ( RCA phono ) - rear ¦ 1 x audio line-out ( RCA phono x 2 ) - rear ¦ 1 x 5.1 channel audio line-out ( RCA phono x 6 ) - rear ¦ 1 x digital audio output (coaxial) ( RCA phono ) - rear ¦ 1 x digital audio output (optical) ( TOSLINK ) - rear ¦ 1 x network ( RJ-45 ) - rear ¦ 2 x USB - front
May 16, 2008 | Toshiba HD-D1 DVD Player
No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Olympus Camedia D-390 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
